Universal Email Not Sending Entire Email Body
Thread begun 10/18/2010 2:55 pm by doug71213 | Last modified 10/19/2010 12:32 pm by Jason Byrnes | 3579 views | 7 replies |
doug71213
All is working great on a long form submit order form, but the entire email body is not being sent. out of 800 lines of code, only about 380 lines are being sent. The form submit page is located at order_form_agent.asp
Please advise.
thanks!
can you provide a little more detail?
Are there specific form elements that do not send the value?
What specifically is missing from the email?
can you send a copy of the wa_universalEmail folder so i can see haw the email was created.
doug71213
Here is the code where the page stops showing. It shows the 1st <tr>, but not the 2nd <tr>, with another 50 <tr> to follow that do not show in the email as well.
<tr>
<td><input name="pquantity58" type="text" class="bodytext" id="pquantity58" value="0" size="3"></td>
<td><input name="pprice58" type="hidden" id="pprice58" value="5.40"></td>
<td>Bioenergized Detoxifying Body Salt-$5.40</td>
</tr>
<tr>
<td><input name="pquantity59" type="text" class="bodytext" id="pquantity59" value="0" size="3"></td>
<td><input name="pprice59" type="hidden" id="pprice59" value="5.40"></td>
<td>Bio Energized Detoxifying Body Salts-$5.40</td>
</tr>
I will also need a copy of the order_form_agent.asp
can you elaborate on what you mean by "the code stops working"?
doug71213
What I mean by code stops working is: it doesn't show in the email. All the code/content for the 1st part of the email shows, but not the last part. It just doesn't show in the email.
madoka2000259126
UNIVERSAL EMAIL 3 Can't send Email
Hi, replaced Xhtml file and still does not work. Need help.
please send a copy of the page that does not work.
