Cannot view uploaded images
Thread begun 10/18/2010 2:39 am by Jordan | Last modified 10/18/2010 1:35 pm by Jason Byrnes | 3771 views | 15 replies |
Jordan
Hello, I would really like some assistance on how to view uploaded images. It would seem that the information for the uploaded image isnt being sent to the database, I think.
I have followed the guides but still no luck.
When I go to the details page all I see is a broken image icon. When I check the database, I see no referral to the uploaded image, however the image is being uploaded and resized fine.
Thank you for your help on this one.
do you see the uploaded file in the upload directory?
please send a copy of your pages in a zip archive so i can examine the code.
Jordan
Hi, thanks for the reply. Yes the file goes to the correct folder ok but just doesnt register on the database. I have run through the things said in the forum before, but I tried the things that relate to me. I just hope that I missed something easy. I'm sure it is that.
In the insert record behavior, the product image column is bound to the product image form element. you will need to edit this and bind the WA Uploaded Files (ProductImage) - > Server File Name instead.
Jordan
I feel a little silly, but could you simplify that a little more for me? I think I am still not really getting it, sorry.
Do I do this from the file upload behaviour?
Thank you.
No you need to edit the Insert Record server behaivor.
Go to Window -> Server Behaviors.
Double click the insert record server behavior to edit it.
select the ProductImage column.
click the lightning bolt icon next to value.
select the WA Uploaded Files (ProductImage) - > Server File Name variable.
Jordan
Strange that it isn't working. I used the value:
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>
I have also compared everything to the powerstore script that I have but still no joy.
I will create another test to see if it works then. Thank you for your help so far.
on the detail page, you need to add the path to the uplaod folder in the image source:
<img class="WADADetailsMainImage" src="../images/productImage/<?php echo $row_WADAproducts["ProductImage"]; ?>" alt="" />
Jordan
Thank you for the reply and the help so far.
I can see the file name in the delete page, which tell me the database is seeing it, however unfortunately the image in the details page is not showing.
I have in the source As you have suggested;
<img class="WADADetailsMainImage"src="../images/productImage/<?php echo $row_WADAproducts["ProductImage"]; ?>" alt="" />
Unfortunately it is not showing. Maybe I have missed something else.
on the detail page, right click where the image should be displaying and select "View Image" what is the address in the address bar? Does the image come up?
