Deleted Custom Pages by Mistake
Thread begun 10/17/2010 10:05 pm by Jason Kline | Last modified 10/18/2010 1:33 pm by Jason Byrnes | 3764 views | 7 replies |
Jason Kline
How do I add PowerStore 4 Custom Pages back if I deleted by mistake?
You would need to recreate them in the content management section.
Jason Kline
Hi Jason,
Any help on how to go about doing this. I tried but no luck. It is a little confusing.
Jason
What are you having a problem with?
In the Content management section, click on Custom Pages, There should be 2 content regions defined:
Header
click the plus button next to Custom Page to create a new Custom page.
Jason Kline
Hi Jason,
That's just it. There is no Custom Pages to click on because I accidentally deleted it.
Jason
Wow, I don't see a way to delete the templates, not sure how you did that.
Click the plus button next to content to add a new content location. Name it "Custom Pages" and check the use as template option.
Jason Kline
OK I got it back.
I think I delete the two pages under Custom Pages then delete the Custom Pages template.
Is there a reason why the pages are not in alphabetical order after creating them?
There is only record set used to populate each level of the content list, so the order by clause is used on the top level, because of this the pages level cant be order alphabetically.
