DD on Repeat Selection
Thread begun 10/16/2010 10:30 pm by agmichaca | Last modified 10/19/2010 6:59 am by Jason Byrnes | 2790 views | 3 replies |
agmichaca
Hello I am trying to implement DD on WADA Repeat Selection.
Without repeat works ok, but with repeat selection applied only work Parent Llts.
Is this possible?
Thank you
this is not supported with Dynamic Dropdowns.
You would need to modify the Select list names to include a incrementing variable. for example:
<select name="select_<?php echo($RepeatSelectionCounter_1); ?>" id="select_<?php echo($RepeatSelectionCounter_1); ?>">
you would also need to modify the javascript applied to the onchange event of the select list to use the same incrementing variable.
agmichaca
Working
Thank You Jason is working so fine!!
OK, glad to hear you have it working.
