Redirect to parent from pop up
Thread begun 10/16/2010 4:22 pm by nickj | Last modified 10/20/2010 12:33 am by Daryl | 2527 views | 4 replies |
nickj
I have a small form in a pop-up window, I would like the pop-up to close when I press submit and have the parent window refresh.
The only solution I can think of is to have the submit button be merely a link to the parent and have the parent submit on load.
It would be much cleaner to have the submit button close the window.
Any ideas?
Nick
you could use javascript for this.
Add an onclick="window.close" to the submit button.
nickj
The problem is that the form includes a file upload which fails. I assume it happens after the submit.
really this is not a supported scenario, it will require hand coding the event to close the window.
you could probably do something like set the for to post to itself using a querystring variable.
then use php to include the javascript window.close event using an if statement.
you will need to comfortable with PHP and javascript to get it to work the way you want though.
DarylBeta Tester
I managed to achieve this effect by adding a target attribute to my form. Something like;
<form class="Sharp_Default" id="SimpleLogIn_Sharp_Default" name="SimpleLogIn_Sharp_Default" method="post" action="login.php" target="_parent">
