Image Resizer or Resize on Upload?
Thread begun 10/16/2010 12:36 pm by Daryl | Last modified 10/17/2010 10:53 am by Dave Buchholz | 3190 views | 5 replies |
DarylBeta Tester
I am thinking of getting this extension and have now read all of the IR pages.
Can someone explain why this method should be used instead of the resize on upload in UE4?
It allows more flexability after the fact. If you resize on upload, then change your design later, then you may not have the correct size any more. Also if you use the same image multiple times of different sizes, you don't have to actually save the multiple image field names in the database and you aren't restricted to using only those.
DarylBeta Tester
Thanks Ray
One last question.....
Does this solution support transparent sections of an image therefore leaving them transparent?
Dave BuchholzBeta Tester
Yes it does, another user AlaskaTom posted this example to show how transparent PNG's are treated
DarylBeta Tester
Thanks Dave
Lets go and spend some money!
No worries, I already spent mine and I am very happy with it
