Record Set not retrieving all data???
Thread begun 10/15/2010 11:03 am by elewis93815 | Last modified 10/15/2010 12:13 pm by Jason Byrnes | 3057 views | 5 replies |
elewis93815
I've created website with a search function and a 2nd page that is suppose to load data dynamically via our Mysql database & a record set. When I view the data via the phpMyAdmin online I can see all of the correct data (119 records), however when I view it in the record set it only show 100 of the 119 total records. This is a link to the live website: ns_exhibitors.php
If you do a search for the Rep named: ZOLLETT (this is the 119 person in the database and all names are in alpha order) the search will retrieve this Rep, however he will not show on the Exhibitors link: ns_exhibitors.php
Both pages are feeding from the same database, however the exhibitors link stops displaying data at Rep: Janie Swanson.
Please advise
Thank you!
Erick
please send a copy of your page so I can examine the code.
elewis93815
the files are uploaded Thanks!
you have the repeat region to show only 100 records:
$maxRows_rsExhibitorsAugust = 100;
$pageNum_rsExhibitorsAugust = 0;
Is you are going to limit the repeat region, you will need to add paging controls.
Ether set the repeat region to show all records, or add paging controls so that hte user can select to see the rest of the records.
elewis93815
That fixed my problem THANK YOU VERY MUCH!!!!!
Erick
you're welcome.
