Parse error - unexpected '['
Thread begun 10/15/2010 10:43 am by reecepaulcoleman119173 | Last modified 10/15/2010 11:29 am by Jason Byrnes | 1286 views | 1 replies |
After setting up my product page, I get the following error message:
Parse error: syntax error, unexpected '[' in /home/sites/************.co.uk/public_html/WA_eCart/eCartblush_PHP.php on line 10
I've looked at it over & over again, but I can't see where the problem lies. The product has 3 optional extras which will incur additional charges & as far as I can tell from the guides, the calculation is right. But I'm probably missing something very obvious!
Here is my code:
//start node
function ResetCalculations($itmObj) {
$itmObj->TotalWeight = $itmObj->Weight * $itmObj->Quantity;//w
$itmObj->TotalPrice = ($itmObj->Price + [sizePriceInc] + [AddonPriceInc] + [delPriceInc]) * $itmObj->Quantity;//c
$itmObj->FullDetails = $itmObj->Quantity . ' ' . $itmObj->Name . ' (' . $itmObj->ID . ')';//t
$itmObj->truePrice = $itmObj->Price + [sizePriceInc] + $itmObj->AddonPriceInc + [delPriceInc];//c
return $itmObj;
//end node
Can someone shed some light on this error?
you need to create the sizePriceInc and AddonPriceInc columns in the cart before you can use those columns in your calculation.
Remember, column names are case sensitive. If you create the column using any uppercase characters, you need to match those when typing the column name in the calculation.
