Show Region Utility
Thread begun 10/15/2010 4:28 am by paul377172 | Last modified 10/15/2010 9:56 am by Jason Byrnes | 3679 views | 3 replies |
paul377172
Show Region Utility
Hi basically what I'm trying to is show a particular form button only if a conidtion is met. I tried validation toolkit but woildnt work with that, then I read on another thread that it would work with the Show Region Utility that comes with Search for Boss, so I purchased that.
However I can get it work but not after a repeat region is displayed. It will work anywhere before the repeat region and with the repeat region but not after it. Can you help with this please.
Paul
after the repeat region, the recordset pointer is at the end of the recordset. you need to move the pointer back to the first row using the following code before the Show region Code:
mysql_data_seek
($WADAorderdetails0);
$row_WADAorderdetails mysql_fetch_assoc($WADAorderdetails);
paul377172
Thanks once again thats sorted
you're welcome.
