Can't import Menu Writer Theme into Preset Manager
Thread begun 10/15/2010 3:59 am by Rune Brynestad | Last modified 10/18/2010 10:34 am by Jason Byrnes | 2470 views | 4 replies |
Rune Brynestad
I want to use the Website template "Sporty" located under Premium Templates in My Downloads as a starting point for a new css design. The Sporty website should be compatible with SiteAssist Professional, Css Sculpture and Css Menu Writer. I can easily import it into SiteAssist Professional and Css Sculpture using the related zip files, but I'm unable to import it into Css Menu Writer.
I'm attaching the Sporty_Menu.zip file. Could there be something wrong with the file ?
I have successfully imported the Horizontal Dusk menu template into Preset Manager, so my guess is that it's something wrong with the Sporty_Menu.zip file.
Regards
Rune
i was able to import this menu preset without an issue.
After downloading the zip file you attached, I went to Insert -> WebAssist Preset Manager.
In the Product Dropdown list I selected CSS Menu Writer - Menu Themes. Clicked the Import button and selected the Sporty_Menu.zip file.
can you provide more details on the problem you are having?
What are the exact steps you are taking?
Do you get an error message?
If so, what is the error?
What version of Dreamweaver?
What version of Menu Writer?
What is your OS?
Rune Brynestad
My steps are exactly the same as you describe.
I don't get any error messages. The Preset Manager window "hangs" (Not Responding) and I need to force Dreamweaver to shut down to get out of the Preset Manager Window.
I use Dreamweaver CS5, Build 4964
CSS Menu Writer version is 2.0.5
My OS is Windows 7 64 bits
I have deleted the winfile cache.
Rune Brynestad
It's working now. I had to rename my configuration folder and start over again with only Css Menu Writer installed. Probably a conflict with another extension.
Regards
Rune
Ok, glad to hear you have it working.
