Session variable not being sent
Thread begun 10/14/2010 11:36 am by mrobben375515 | Last modified 10/19/2010 10:15 am by Jason Byrnes | 1634 views | 3 replies |
mrobben375515
I've used security assist to create a login page and I'm trying to save the username as a session variable and call for it in the page that it's redirected to after validating the name and password. I can't get the variable to show up, and I've tried several different options in the set session variable menu for the trigger with no success. I've attached the two pages... thanks
double click the authenticate user server behavior.
On the third page of the wizard, you can select database columns that should be stored in session variables after login, click the plus button and select the username column.
mrobben375515
Perfect, thanks for the help.
you're welcome.
