2 update server behaviours on one page
Thread begun 10/14/2010 4:34 am by paul377172 | Last modified 10/14/2010 1:43 pm by Jason Byrnes | 2456 views | 5 replies |
paul377172
I am using DA Multiple records with a repeat region to store individual values from a form into the orderdetails table created by ecart5 and that works great. On the same page I'm also using update single record to calculate the total values from the orderdetails table but thats not entering the value into that table column. If I submit the form twice it does. What do i need to do to get it to enter the values into both tables.
Sorry if If I am not explaning myself very well. I have tried all sorts of different methods. I tried a javascript to calculate the values into the form fields for me so it would be quite easy to do from there. I know I could add a confirmation page and add an update record into that and that would work, but can i do it all from the same page.
can you send a copy of the page so i can see how it is configured.
paul377172
ok its very basic at the moment but just trying to get it to work first
the issue is code order.
the code for performing the update is after the code that creates the recordset.
you need to rearange the code so that the recordset code is between the multiple update and the single update code.
paul377172
Thanks very much.
you're welcome.
