Product Options Issues
Thread begun 10/14/2010 1:31 am by rob256926 | Last modified 10/20/2010 1:01 pm by Jason Byrnes | 2315 views | 5 replies |
rob256926
I'm using the Product Options tutorial to try to drop size and color options into my store.
When I test my store the dynamic list/menu is not populating. If I change the "Options from recordset" from my rsColor to the products record set, rsProducts, the list will populate with all of my products.
Here is my SQL Code:
SELECT productoptions.OptionPriceincrement, productoptions.ProductOptionID, options.OptionName, options.OptionGroupID, optiongroups.OptionGroupName
FROM options INNER JOIN productoptions ON options.OptionID = productoptions.ProductOptionID INNER JOIN optiongroups ON options.OptionGroupID = optiongroups.OptionGroupID
WHERE optiongroups.OptionGroupName = 'color' AND productoptions.ProductID = paramItem
And the Variables
Type: paramItem
Default Value: -1
Runtime Value: $row_rsProducts['ProductID']
When I created my add to cart button I left the color "Default Value" blank under the Bindings tab. Should this have a database call in it? I'm also not doing a price increase so I didn't do anything with the sizeInc. calculations.
can you send a copy of the page so i can see the entire code in context, this will help me see where the issue is.
rob256926
Here you go
DarylBeta Tester
Hi Rob
When you get a solution, could you post it here as I will soon be attempting this....
we found a problme in the SQL.
we edited the SQL to:
FROM options INNER JOIN productoptions ON options.OptionID = productoptions.OptionID INNER JOIN optiongroups ON options.OptionGroupID = optiongroups.OptionGroupID
to get the options working.
This change will be made in the documentation as well.
