JavaScript error CreateEmailMessage_WA.htm
Thread begun 10/13/2010 10:44 pm by adrian214133 | Last modified 10/25/2010 1:35 pm by Jason Byrnes | 5592 views | 3 replies |
adrian214133
I am using UE4 with CS4 and receiving the following error initially after configuring all required UE4 values then attempting to create the behavior. I am now receiving the same error when attempting to add the UE4 behavior to a page.
"While executing applyServerBehavior in CreateEmailMessage_WA.htm, a JavaScript error occurred."
The DW cache has been deleted, old UE3 and DigitalDownload extensions had been removed prior to installation of UE4.
can you send a copy of your page so I can try to recreate the issue.
CUAD
JavaScript error when executing WA Unerversal Email.
I get an error that reads " While executing timer in WA Universal Email.htm, the following JavaScript Error(s) occured:
At line 417 of file "C:\Program Files\Adobe\Adobe Dreamweaver CS4\ Configuration\Commands\WA Uneversal Email.js": theFiles[x]getAttribute("type")has no properties
This happens when I go to webassist --> create email message.
This is with Universal Email 4
this error occurs if you have form elements on your page that do not have a type attribute set.
make sure that each form element has a type attribute defined.
