Problem with links and images
Thread begun 10/13/2010 6:22 pm by Jade but not jaded | Last modified 10/15/2010 6:42 pm by Dani Chankhour | 3770 views | 7 replies |
Jade but not jaded
Hi again,
I'm having another problem with PowerCMS 2.
For reference, I think my problems stem from the fact that I installed PowerCMS into a folder within the root folder, rather than in the root itself, e.g. /cms/ instead of just /
I say this due to a lot of prior experience with over 20 other Webassist products that I own that have given me grief when I tried to put the support files anywhere other than the root.
I also say this because the problem I'm encountering is with browsing for images or browsing for files. In both instances, PowerCMS is only looking within the /cms/ folder and won't let me browse above that folder.
I've searched the forum and have found similar problems from other users, but unfortunately, they typically end with a suggestion to continue the issue in a support ticket rather than in the forum. Or they reference changes to the WA_Globals.php file for the previous version of PowerCMS (I'm using version 2, not 1).
As a result, there are no solutions publicly available for me.
Anyway, my problem is:
In the editing interface, if I click the "browse server" button in either the "image" or "link" tools, I am faced with a file navigator window that only shows me files within the /cms/ folder.
Also, if I try changing the path to the "image upload folder" on the settings tab, PowerCMS corrupts my change by prepending what it imagines the path should be, so for example:
If I try to change "/home/wedgem5/public_html/cms/" to "/home/wedgem5/public_html/images/" and then click save, PowerCMS overwrites my change and makes it "/home/wedgem5/public_html/cms//home/wedgem5/public_html/images/"
So, anyone have any ideas how to solve this problem?
Please keep in mind that I'm using PowerCMS 2, not 1, which means my WA_Globals.php file doesn't have the same configurability that the previous version did.
Looking forward to some help with this.
Jade
Dani Chankhour
The way powercms is designed is to store the images in the cms folders. You can change the path where it looks at the root of your site by going to admin/common and open the listfolder.php file and change this line of code:
if(file_exists($parent) && strpos($parent, $root_folder) !== false) {
to
if(file_exists($parent)) {
this will let you browse outside your cms files.
Jade but not jaded
Hi Dani,
Thanks for your response.
Unfortunately, this doesn't solve the problem for either image browsing or link browsing.
I'm still being limited to the /cms/ folder.
Any more ideas?
Dani Chankhour
Once you made that update you will need to go to the settings tab and then browse to the root of your site. The change i gave you allowed you to browse outside the cms files.
Jade but not jaded
part rainy
Hi Dani,
I see what you mean, but unfortunately, as I said, it doesn't work.
Here's what's happening:
I go to settings and by default, the images folder is specified already as: /home/wedgem5/public_html/cms/
As you described, I am now able to "view parent folder" and navigate to the root, which is /home/wedgem5/public_html.
But when I try to select the root and click save, the images folder path is prepended with the original, resulting in this:
No matter how many times I try, PowerCMS continues to prepend the original path to the /cms/ folder.
Any thoughts?
Dani Chankhour
Sorry, it seems that the change we have to make is in the HTMLEditor folder.
in the HTMLEditor Folder under editor/plugins/kfm and open the configuration.php file.
Then change this line of code:
$kfm_userfiles_address = '../../../../'.$WAGLOBAL_images_folder;
to
$kfm_userfiles_address = '../../../../';
$kfm_userfiles_output = $WAGLOBAL_images_folder . '/';
to
$kfm_userfiles_output = '/';
note, this implies that you won't be able to use the settings tab to set your images folder. it will always default to the root.
Jade but not jaded
Hi Dani,
I'm afraid this doesn't work either. In fact, it doesn't seem to have any effect at all.
Any more ideas?
Thanks,
Jade
Dani Chankhour
Are you using Advanced Images Upload?
If not, then you will need to make the same changes in different file:
HTMLEditor/editor/filemanager/connectors/php/config.php
