Checkout does not continue past confirm.php
Thread begun 10/13/2010 11:15 am by SaladoGuy | Last modified 10/13/2010 4:26 pm by Dani Chankhour | 2709 views | 7 replies |
SaladoGuyBeta Tester
I had a cart working (or maybe it was almost working) with authorize.net. I went to test it today and realized that it does not proceed to the final pages (checkout_success.php or checkout_failure.php)
Everything else seems to be working: the confirmation email is received from both eCart and authorize.net, and the order and order details entries are posted correctly.
So it seems that everything is working except that it's not proceeding to the checkout_confirm.php page.
Can you please look at the code and let me know what's wrong with it?
I'm attaching a zip file with (I hope) everything we need.
Thanks.
Zip attached here.
I removed the authnet keys from the code (for obvious reasons)
Dani Chankhour
is the order being stored correctly in your database and is the transaction showing under Authorize.net?
Yes, order is being stored correctly in the database ("... the order and order details entries are posted correctly ...").
Re: "is the transaction showing under Authorize.net"
Authorize.net is in test mode:
"ACCOUNT IS IN TEST MODE - REAL TRANSACTIONS WILL NOT BE PROCESSED"
I do not have any way to know or prove that they are reaching authorize.net correctly (it does not seem to store "test" transactions) however I believe it is working correctly since (as I mentioned before) we are getting a valid test confirmation email FROM authorize.net with all the corect information. So apparently that means authorize.net is receiving everything from our shopping cart that it is supposed to be receiving.
If you can give me instructions on how to provide you with better information than that, please do. All this is new to me.
In the mean time - we're stil anxiously waiting your report on what might be wrong with the current page. We suspect it must be a problem with the confirm.php page but we don't know for sure.
Dani Chankhour
You are correct, looking at the confirm page and comparing it to my confirm page, it looks like it is missing the redirect call.
At the end of line 584, please add these lines of code:
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
so you should have:
if ($eCart1->IsEmpty()) {
$eCart1->redirStr = "viewcart.php";
$eCart1->cartAction = "RedirectIfEmpty";
That fixed it, thank you.
Dani Chankhour
I'm glad i was able to help.
