Powerstore All Versions - Products Image placeholder
Thread begun 10/13/2010 7:14 am by Jason Kline | Last modified 10/22/2010 11:46 am by Dani Chankhour | 5121 views | 14 replies |
Jason Kline
Does PS have to ability to check for missing product images in the imagesupload folder and provide a default placeholder image?
Dani Chankhour
No, but that is something that could be added. However with Powerstore v4, you don't have to add an image when you insert a product, because we default to a default image if no image was specified.
Jason Kline
Sounds like this could be added in the next update to PS 3.0.1 right?
Dani Chankhour
I'm not sure that is something that could be added to PS 3, because that is not how it is designed. But i can provide with a work around on how to go about showing a default image if the image does not exists. Although that seems like it is not really possible because PS 3 requires an image before creating a new product.
Jason Kline
If can provide this work around it would be helpful for those who have 7000+ products with images and will import via a database backend.
Jason Kline
I just added this code to the Product_Results.php page and it works.
onerror="this.src = 'noimage.jpg'"
<div class="imageWrapper"> <a href="Products_Detail.php?ProductID=<?php echo(rawurlencode($ProductID)); ?>" title="<?php echo $row_WADAProducts["ProductName"]; ?>"> <img class="WADAResultThumb" border="0" src="imagesupload/<?php echo $row_WADAProducts['ProductThumb']; ?>" onerror="this.src = 'noimage.jpg'" /></a> </div>
But whatever you provide I will use.
Thanks Dani.
Dani Chankhour
You can add these lines of code before the image tag:
$file = "imagesupload/" . $row_WADAProducts['ProductThumb'];
if(!file_exists($file)) $file = "imagesupload/default-product.png";
and update the image tag to:
<img class="WADAResultThumb" border="0" src="<?php echo $file; ?>" />
Jason Kline
Thank you Dani.
That works very well.
Your awesome.
Dani Chankhour
I'm glad i was able to help.
you can use that concept any where where images are displayed (detail page, cart, etc...).
Jason Kline
Now that I have purcahsed PS4 after importing products the placeholder image is missing for all products. How can this be rectified?
Seems like the placeholder image only come when you add a product from with the store manager. But I don't think one would expect that we would sit and enter couple thousand products manually right?
