Paypal standard for Sweden?
Thread begun 10/13/2010 2:34 am by olle189996 | Last modified 2/22/2011 1:16 pm by Jason Byrnes | 3711 views | 5 replies |
olle189996
Hi.
I'm thinking of using eCart for a Swedish webshop.
So I need a easy way for accepting creditcards payments.
I'm thinking of using Paypal standard for that. Would eCart be functioning with a swedish account in Paypal?
Also. Will eCart support the swedish currency?
Regards
Olle
Dani Chankhour
eCart does not support the Sweden currency (krona). And in regard to using PayPal Standard, you will need to check if PayPal accept Sweden Currency. If it does we can change the code that is generated be eCart to send the correct information to PayPal. But first will need to know if PayPal supports Sweden currency.
olle189996
Hi
Yes Paypal supports Sweden! se
The only thing I need for the currency in eCart would be to change maybe the € to Kr (for krona). Would that be a hard task?
Or is there more things to concider when you say that eCart does not support Kr?
Regards
Olle
Dani Chankhour
if PayPal support krona, then eCart should have any limitation. We might just have to modify it a little bit to display the correct currency symbol.
regin.toftegaard421288
Danish Currency
I also would like to have the danish currency embedded since I right now am building a web-shop for a danish company. Denmark also uses kroner, but the value of the currency is different than the Swedish. PayPal Denmark supports this currency.
Can this be changed soon, or is there any workaround I can use until this issue has been fixed?
you asked this question in another thread as well, see my reply there:
showthread.php?t=19013
