Street View
Thread begun 10/12/2010 2:52 pm by enaitove124280 | Last modified 10/14/2010 11:42 am by Dani Chankhour | 3254 views | 6 replies |
enaitove124280
Street View
is there a way to zoom in and have the actual street view (grab the litlle person icon at google maps) onto the map and see the real street view?
Dani Chankhour
Pro Maps for Google does not do street view. But if you add these two lines of code to your javascript file, you will get the street view:
panoramaOptions = { latlng:point };
myPano = new GStreetviewPanorama(document.getElementById("wagmp_map_1"), panoramaOptions);
However, those lines will need to change based on your map. But for the most past those lines of code should be placed under this line of code:
wagmp_map_1_obj.points.push(point);
enaitove124280
Street view
I have looked in both my wagmp_map_1.asp file and wagmp_maps.js file and do not see anyline that contains anything that resembles
The only lines in my js file are listed below:
window.onunload = function() {
GUnload();
/*wagmp_onload*/
if(window.wagmp_map_6) wagmp_map_6();
if(window.wagmp_map_5) wagmp_map_5();
if(window.wagmp_map_4) wagmp_map_4();
if(window.wagmp_map_3) wagmp_map_3();
if(window.wagmp_map_2) wagmp_map_2();
if(window.wagmp_map_1) wagmp_map_1();
enaitove124280
street view
my bad. I found it. I am using my 6th map created. But here's my other question.
This line
wagmp_map_6_obj.points.push(point);
appears 3 times. Do I place the 2 lines of code you supplied under each instance?
Dani Chankhour
Correct. replace it in all instances where that line shows.
enaitove124280
street view
that does not do the trick. what I am looking to do is when you go to a map at google and zoom down, in thw zoom bar you can "drag" a little icon and place it in the map and then it looks like you are standing on the street looking around
Dani Chankhour
OK, however that seems to require a lot of custom coding and currently our map does not support this feature.
