Parts of sub menus hidden
Thread begun 10/12/2010 12:55 pm by larry268887 | Last modified 10/13/2010 3:26 pm by larry268887 | 3126 views | 6 replies |
larry268887
I've completed converting my popmenu magic menu to a css menuwriter menu. The only problem now is that submenus near the bottom of the page have part of the menu hidden.
My content area has the overflow as hidden. If I remove this statement then the menu is properly displayed but is messes up the layout of the website. I've attached all the pertinent files.
could you take a look and let me know what I doing wrong.
Larry
Dani Chankhour
I'm missing the menu writer files.
If you have a link to the site, that would work too.
larry268887
Link to Page with Menu
Here is the link to the page with the Menu.
Untitled-1.html
Larry
Dani Chankhour
Thanks.
Try removing the overflow:hidden.
and instead add clear:left to your clearFloat class.
larry268887
made changes still not right
By removing the overflow hidden allows the menu to work correctly but then allows the footer to rise and not be in the right position. Adding the clear:left didn't correct the problem.
You can view the page with the changes you suggested at the link in the earlier post.
Larry
Dani Chankhour
I don't see the clear float being added.
in your css file make sure to add this class:
.clearFloat {
clear:left;
larry268887
working
ok I see what your saying and it works.
Larry
