Error on checkout (needs attention)
Thread begun 10/11/2010 3:44 pm by johnb | Last modified 10/13/2010 3:45 pm by Jason Byrnes | 4724 views | 6 replies |
johnb
Need some assistance getting PS3 to process the payment. It keeps telling me there is a duplicate order.
As a sidenote I have modified PS3 to use Firstdata (linkpoint) to process payments. This was working on the test server before but now its not on the live server.
Id like to add that no orders are showing in the database either.
When a payment is processed the failure page outputs the following results:
...AVS
746fa410f270d6bece14faf3ce0a851d ...Order Number
SGS-005003: The order already exists in the database. ...Error
DUPLICATE ...Approved
...Code
...Message
Mon Oct 11 18:36:41 2010 ...Time
...Ref
...tdate
...Tax
...Shipping
...Score
1001245243/home/stnicks/public_html/linkpoint/1001245243.pemsecure.linkpt.net1129SALELIVE0.647.957.9516.54Shawn Sealy5221 S. Santa Fe Dr.LittletonCO80120US720-581-1882shawn@stnicks.com54741501008346120912218Shawn Sealy5221 S. Santa Fe Dr.LittletonCO80120US117.95NUNSPECIFIED746fa410f270d6bece14faf3ce0a851d944100 Icicle Lights Clear (White Cord)7.951Mon Oct 11 18:36:41 2010SGS-005003: The order already exists in the database.746fa410f270d6bece14faf3ce0a851dDUPLICATE
Any Ideas?
CraigRBeta Tester
I have taken a look at this in an attempt to help John out, but haven't got much further, other than when I attempt a transaction for the first time, i get a transaction declined.
Any subsequent attempt gets the duplicate order message.
I have taken the source from the failed transaction page in each instance and a modified version is below
<order>
<merchantinfo>
<configfile>1000000000</configfile>
<keyfile>/path/1000000000.pem</keyfile>
<host>secure.linkpt.net</host>
<port>1129</port>
</merchantinfo>
<orderoptions>
<ordertype>SALE</ordertype>
<result>LIVE</result>
</orderoptions>
<payment>
<tax>2.4</tax>
<shipping>15.95</shipping>
<subtotal>29.95</subtotal>
<chargetotal>48.30</chargetotal>
</payment>
<billing>
<name>John</name>
<address1>S Garland St</address1>
<address2></address2>
<city>Lake</city>
<state>CO</state>
<zip>80226</zip>
<country>US</country>
<phone>303</phone>
<fax></fax>
<email>johntest@logo.com</email>
</billing>
<creditcard>
<cardnumber>4111111111111111</cardnumber>
<cardexpmonth>12</cardexpmonth>
<cardexpyear>12</cardexpyear>
<cvmvalue>123</cvmvalue></creditcard>
<shipping>
<name>John</name>
<city>Lake</city>
<state>CO</state>
<zip>80226</zip>
<items>1</items>
<weight>1</weight>
<total>29.95</total>
</shipping>
<transactiondetails>
<taxexempt>N</taxexempt>
<terminaltype>UNSPECIFIED</terminaltype>
<oid>bcdf1fd6f946e2bee1d24cee082cdb68</oid>
</transactiondetails>
<items>
<item>
<id>992</id>
<description>10 Budweiser Can Lights</description>
<price>29.95</price>
<quantity>1</quantity>
</item>
</items>
</order>
<r_csp></r_csp>
<r_time>Tue Oct 12 08:48:33 2010</r_time>
<r_ref></r_ref>
<r_error>SGS-000001: D:DeclinedXXUX:</r_error>
<r_ordernum>bcdf1fd6f946e2bee1d24cee082cdb68</r_ordernum>
<r_message>DECLINED</r_message>
<r_code></r_code>
<r_tdate>1286887713</r_tdate>
<r_score></r_score>
<r_authresponse>X07</r_authresponse>
<r_approved>DECLINED</r_approved>
<r_avs></r_avs>
Test 2
<order>
<merchantinfo>
<port>1129</port>
</merchantinfo>
<orderoptions>
</orderoptions>
<payment>
<tax>2.4</tax>
<shipping>31.9</shipping>
<chargetotal>64.25</chargetotal>
</payment>
<billing>
<name>John</name>
<city>Lake</city>
<state>CO</state>
<zip>80226</zip>
<phone>3039193007</phone>
<fax></fax>
</billing>
<creditcard><cardnumber>4111111111111111</cardnumber>
<cvmvalue>456</cvmvalue>
</creditcard>
<shipping>
<name>John</name>
<city>Lake</city>
<state>CO</state>
<zip>80226</zip>
<items>1</items>
<weight>1</weight>
</shipping>
<items>
<item>
<id>992</id>
</item>
</items>
</order>
<r_csp></r_csp>
<r_time>Tue Oct 12 08:57:19 2010</r_time>
<r_ref></r_ref>
<r_error>SGS-005003: The order already exists in the database.</r_error>
<r_message></r_message>
<r_code></r_code>
<r_tdate></r_tdate>
<r_score></r_score>
<r_authresponse></r_authresponse>
<r_approved>DUPLICATE</r_approved>
<r_avs></r_avs>
If anyone has used this payment gateway before, can I check, do the test c/c details work in a live environment ?
on the confirm page, how is the oid being generated:
$LinkPointAPI_itemized[0][1] = "transactiondetails->oid";
  $LinkPointAPI_itemized[1][1] = "".session_id()  ."";
usually, it should use the session_id()
if it is using the session_id() already, make sure that the session id is working correctly.
Create a new page and add the following code:
if(!session_id()) session_start();
echo(
session_id()); ?>
open this page in fire fox, then again in IE and compare the ID's, they should be different.
johnb
According to your reply everything checks out okay.
If a customer places an order that declines and then tries to place it again correctly will the session cause it to send the same order number causing the transaction to fail as a duplicate? Or if they place one successful order then place a second successful one afterward?
trey adding this code on the success page at the very end:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
@session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params session_get_cookie_params();
setcookie(session_name(), ''time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
session_destroy();
session_regenerate_id();
johnb
I see this code already at the end:
if ("" == ""){
// WA_ClearSession
$clearAll FALSE;
$clearThese explode(",","OrderID,WA_Store_Cart_Items,specialinstructions");
    if(
$clearAll){
        foreach (
$_SESSION as $key => $value){
            unset(
$_SESSION[$key]);
    else{
        foreach(
$clearThese as $value){
            unset(
$_SESSION[$value]);
How is he code you suggested to put at the end different? I guess I'm asking what it does differently? Also would I replace this code or add it afterward?
that code just clears the session variables, it will not reset the session id.
You can replace that code or just add the new code after it.
either way will work
