missing delete
Thread begun 10/11/2010 3:46 am by i.edwards384429 | Last modified 10/12/2010 1:36 pm by Jason Byrnes | 2990 views | 6 replies |
i.edwards384429
missing delete
Hi
clearly going insane.
Page nine of the idiot guide - Ok I'm an idiot- entitled "setting the results page options"
has at the top an add cross followed by a delete dustbin.
But my installation in step 4 of nine has no + or delete options.
I've attached a screen dump of what I see.
I'm running W7 64 bit.
thanks
Ian
i.edwards384429
update
Hi
I've also just noticed that in the tutorial are colums
column, label and link to detail
whereas on my screen Im see
column, value and link to detail.
thanks
Ian
neilo
That's weird. What version of DataAssist are you running?
Maybe it's a Windos7 64bit thing, but I don't get the 'wireframe' area, - I'm running the latest version (on Vista) and get the attached.
i.edwards384429
update
Hi
Ok so its just me, ( not a surprise) sure it's because I've ticked a box or soemthing.
I'm running V 2.07 which is the latest.
No doubt I'll find out tomorrow ;-)
Thought this would be a simple project ........
cheers
Ian
It's because you have selected to use the Public page type on step 3 instead of the Administrative page type.
In the Public page type, you cannot add or remove areas from the wire frame, only chose which columns to use in each area of the wire frame.
i.edwards384429
update
Thanks Jason
I suspect I'll have another couple of queries tomorrow so I'll get ahead of the game ;-)
Using the dataassist wizard defaults is the search exact or can a vaiance be built in.
ie in my case fields are price, length etc and I'd like a search of say £10,000 to list 950000 to 10500 similalry with length
trust you has a good days holiday
Ian
you cant do this in the wizard, but if edit the DataAssist search server behavior after the pages have been created, you can add the conditions to the criteria list.
