Error in DataAssist Wizard
Thread begun 10/10/2010 5:15 pm by jspoerer286380 | Last modified 10/15/2010 12:55 pm by Jason Byrnes | 3114 views | 5 replies |
jspoerer286380
Hi, I was following the DataAssist Wizard by the manual and everything seems to work fine until the end... When I press the FINISH button I receive the error message I include in the attached picture.
DW creates only one page (users_results.asp) and stops...
Kind of frustrating !!
Some help needed please...
Best Regards,
Jorge Spoerer from Chile
jspoerer286380
additional information..
BTW... I´m using:
- DW CS5
- Windows 7
- ASP VBscript
- MS-ACCESS
jspoerer286380
Hi, I just noted that also 2 new templates files are created under the [Templates] directory. Before running the Wizard there were only 2 files:
siteassist_config.cfg
siteassist_template.dwt.asp
after pressing the [FINISH] button it generates 2 more files ended in:
._wa_0.asp.htm and
._wa_1.asp.htm
don´t know if this helps but anyway...
Thank You & Best Regards,
Jorge Spoerer
What version of DataAssist?
can you send a copy of your access db in a zip archive so I can try to recreate the issue?
jspoerer286380
your questions
I´m using DataAssist vs. 2.07
I have included the ACCESS file... Thank You
Jorge
