Dynamic Plugin Question
Thread begun 10/08/2010 3:53 pm by Dave Buchholz | Last modified 10/12/2010 2:05 pm by Dave Buchholz | 2419 views | 4 replies |
Dave BuchholzBeta Tester
How can I loop through a recordset result and use the rows as a comparison against the Trigger Variable ?
Is this possible ?
Dani Chankhour
After creating the record set, you can select the trigger value in the Dynamic Plug-in UI to use a column from the record set, and after the code has been put on the page, you can surround the Framework code with a loop that loops over the record set. However, the plug-in name will also have to be stored in the database as well.
Dani,
Can I not just store the plugin name as a variable ?
Dani Chankhour
yes, you can store it in the database as a column value and in the UI, you can just use that as the plug-in name.
ok thanks Dani
