PowerStore 3 - Error message when attempting to checkout
Thread begun 10/08/2010 8:05 am by kgarrett369013 | Last modified 10/13/2010 12:58 pm by Jason Byrnes | 3691 views | 8 replies |
kgarrett369013
When checking out on Powerstore site I setup we an error message that says our credit card information or billing address information is invalid. Is this there an area of the settings that I am missing?
add the following code to the failure p[age:
if(!session_id()) session_start();
 if(
$WAGLOBAL_Gateway == 1 ) {
     echo
"<p>Direct Pay: <br />";
     echo
"Full Request: ".(isset($_SESSION["PP_DirectPayment_postedValues"])?htmlentities($_SESSION["PP_DirectPayment_postedValues"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["PP_DirectPayment"])?htmlentities($_SESSION["PP_DirectPayment"]):"n/a")."<br /></p>";
     echo
"<p>Express Authorize <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Auth_Request"])?htmlentities($_SESSION["ECO_Auth_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br />";
     echo
"<p>Express Process: <br />";
     echo
"Full Request: ".(isset($_SESSION["ECO_Process_Request"])?htmlentities($_SESSION["ECO_Process_Request"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["ECO_Process_Result"])?htmlentities($_SESSION["ECO_Process_Result"]):"n/a")."<br /></p>";
 if(
$WAGLOBAL_Gateway == 2) {
     echo
"<p>Auth Net: <br />";
     echo
"Full Request: ".(isset($_SESSION['WAAuthNet_postedValues'])?htmlentities($_SESSION['WAAuthNet_postedValues']):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION['WAAuthNet'])?htmlentities($_SESSION['WAAuthNet']):"n/a")."<br /></p>";
  if(
$WAGLOBAL_Gateway == 3 ) {
     echo
"<p>Express Authorize: <br />";
     echo
     echo
"Full Response: ".(isset($_SESSION["ECO_Auth_Result"])?htmlentities($_SESSION["ECO_Auth_Result"]):"n/a")."<br /></p>";
     echo
     echo
     echo
 if(
$WAGLOBAL_Shipping == 1) {
     echo
"<p>UPS: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_UPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_UPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_UPS_FullResponse"]):"n/a")."<br /></p>";
 if(
$WAGLOBAL_Shipping == 2) {
     echo
"<p>FedEX: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_FedEx_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_FedEx_FullResponse"]):"n/a")."<br /></p>";
 if(
$WAGLOBAL_Shipping == 3) {
     echo
"<p>USPS: <br />";
     echo
"Full Request: ".(isset($_SESSION["WA_Store_Cart_USPS_FullRequest"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullRequest"]):"n/a")."<br />";
     echo
"Full Response: ".(isset($_SESSION["WA_Store_Cart_USPS_FullResponse"])?htmlentities($_SESSION["WA_Store_Cart_USPS_FullResponse"]):"n/a")."<br /></p>";
this will write the full request and full response from the gateway to the screen to help us see what is wrong.
NOTE: The full request and full response will contain private information that should be removed before posting here.
kgarrett369013
which part of the failure page?
sorry, I'm completely new to php
add that code just after the <body> tag.
kgarrett369013
do i need to attempt to checkout in order to see the failure page and get the info i need?
yes, after adding the code, you need to run through the checkout process again, this time, the code you added will write the full request and full response from the gateway to the page so we can use this for troubleshooting.
kgarrett369013
Here is what I received (*=info I removed)
Auth Net:
Full Request: n/a
Full Response: n/a
UPS:
Full Request: <?xml version="1.0"?><AccessRequest xml:lang="en-US"><AccessLicenseNumber></AccessLicenseNumber><UserId>********</UserId><Password>********</Password></AccessRequest><?xml version="1.0"?><RatingServiceSelectionRequest xml:lang="en-US"><Request><TransactionReference><CustomerContext>Rating and Service</CustomerContext><XpciVersion>1.0001</XpciVersion></TransactionReference><RequestAction>Rate</RequestAction><RequestOption>rate</RequestOption></Request><PickupType><Code>01</Code></PickupType><Shipment><Shipper><ShipperNumber>******</ShipperNumber><Address><City>*******</City><StateProvinceCode>**</StateProvinceCode><PostalCode>*****</PostalCode><CountryCode>**</CountryCode></Address></Shipper><ShipTo><Address><City>evansville</City><StateProvinceCode>**</StateProvinceCode><PostalCode>*****</PostalCode><CountryCode>US</CountryCode></Address></ShipTo><Service><Code>03</Code></Service><Package><PackagingType><Code>02</Code></PackagingType><Dimensions><Length>12</Length><Width>12</Width><Height>12</Height><UnitOfMeasurement><Code>IN</Code></UnitOfMeasurement></Dimensions><PackageWeight><Weight>0.3</Weight><UnitOfMeasurement><Code>LBS</Code></UnitOfMeasurement></PackageWeight></Package></Shipment></RatingServiceSelectionRequest>
Full Response: <?xml version="1.0"?> <RatingServiceSelectionResponse><Response><TransactionReference><CustomerContext>Rating and Service</CustomerContext><XpciVersion>1.0001</XpciVersion></TransactionReference><ResponseStatusCode>0</ResponseStatusCode><ResponseStatusDescription>Failure</ResponseStatusDescription><Error><ErrorSeverity>Hard</ErrorSeverity><ErrorCode>10002</ErrorCode><ErrorDescription>The XML document is well formed but the document is not valid</ErrorDescription><ErrorLocation><ErrorLocationElementName>AccessRequest/AccessLicenseNumber</ErrorLocationElementName></ErrorLocation></Error></Response></RatingServiceSelectionResponse>
kgarrett369013
Any idea on the what the problem might be and what I need to do to fix it?
the error is saying that the access number is not present:
in the PS3 admin go to the shipping settings and make sure to enter a valid access key.
