POWERSTORE4 install to testing directory
Thread begun 10/07/2010 8:58 pm by lyle406399 | Last modified 10/08/2010 11:15 am by Jason Byrnes | 1081 views | 1 replies |
lyle406399
I have installed pw4 to a sub directory on my hosting site and and created a subdomain to direct to the route of pw4. The gallery edit file calls this error.
Warning: require_once(../Connections/PowerStoreConnection.php) [function.require-once]: failed to open stream: No such file or directory in /home/greenlou/public_html/outdoor/admin/global.php on line 3
Fatal error: require_once() [function.require]: Failed opening required '../Connections/PowerStoreConnection.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/greenlou/public_html/outdoor/admin/global.php on line 3
Is this to do with the way the server handles these requests?
ps: I have removed /Powerstore files/ from the directory structure.
does it work correctly if you use the main domain URL to the subdirectory instead of using the subdomain? it may be an issue with the way the subdomain is being mapped.
