insert multiple if checked issue
Thread begun 10/07/2010 6:44 pm by twitchr377598 | Last modified 10/13/2010 2:30 pm by twitchr377598 | 2403 views | 3 replies |
twitchr377598
Once again, I seek the help of the Webassist Gurus. I have a form to create a user and part of the form is a series of dynamically created checkboxes. The check boxes correspond to various venus I want to give the created user access to or not. My plan is to insert the data of only the checked boxes into a table called "venue_user_access". I'm using the insert multiple records behavior and it seems to only work if ALL the check boxes are checked. If only one is checked, then I get the following error:
Column 'venueID' cannot be null
I saw another thread of something similar, but the solution in that thread did not work.
I have attached my code.
Thanks in advance,
Twitch
twitchr377598
Sounds good. Was hoping it was an easy "Oh change this piece of code" fix...haha
twitchr377598
Any word on this issue? I haven't gotten any response in my support ticket.
Thanks in advance,
Twitch
