PS3 load error
Thread begun 10/07/2010 3:46 pm by msjj000 | Last modified 10/08/2010 7:53 am by Jason Byrnes | 991 views | 1 replies |
msjj000Beta Tester
PS3 load error
Hi WA,
This error has come up. Are you able to give me your opinion if this is a hosting error?
Thanks, Mark.
Warning: session_start() [function.session-start]: open(E:\WINDOWS\Temp\sess_ea4c745e64b28e0a3f53d6a43e85bb7a, O_RDWR) failed: Permission denied (13) in C:\inetpub\vhosts\e-marineworld.com.au\httpdocs\store\WA_eCart\WA_eCart_Definition_PHP.php on line 465
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at C:\inetpub\vhosts\e-marineworld.com.au\httpdocs\store\WA_eCart\WA_eCart_Definition_PHP.php:465) in C:\inetpub\vhosts\e-marineworld.com.au\httpdocs\store\WA_eCart\WA_eCart_Definition_PHP.php on line 465
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at C:\inetpub\vhosts\e-marineworld.com.au\httpdocs\store\WA_eCart\WA_eCart_Definition_PHP.php:465) in C:\inetpub\vhosts\e-marineworld.com.au\httpdocs\store\WA_eCart\WA_eCart_Definition_PHP.php on line 465
Warning: Unknown: open(E:\WINDOWS\Temp\sess_ea4c745e64b28e0a3f53d6a43e85bb7a, O_RDWR) failed: Permission denied (13) in Unknown on line 0
Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (E:\WINDOWS\Temp) in Unknown on line 0
from WA_eCart_Definition_PHP.php line 465
function Session_GetContent() {
$retArray = array();
yes, this is a hosting error.
It means that the session.save_path in the php.ini file is not set correctly. Either the session.save_path does not exist, or it does not have the appropriate permissions to create the session temp file.
