Editing the wagmap_map_1.js file
Thread begun 10/06/2010 8:52 pm by Screamin'Dean | Last modified 10/07/2010 1:36 pm by Jason Byrnes | 4843 views | 13 replies |
Screamin'Dean
Hi - I'm trying to get the custom focus function to work. I think my problem is in editing the wagmap_map_1.js file (in particular line 26 - Dreamweaver tells me I have a syntax error when I remove the } bracket)
Can someone please check the below for me. Line 26 is the 3rd from the bottom...
function WAMapRef(mapObj) {
this.obj = mapObj;
this.directions = false;
this.icons = [];
this.markers = [];
this.addresses = [];
this.points = [];
this.getPointByAddress = getPointByAddressFunc;
this.addressFailed = true;
return this;
function WAMapPoint(theMarker, theAddress, theIcon, point, map) {
this.icon = theIcon;
this.marker = theMarker;
this.address = theAddress;
return this;
map.setCenter(point, 13);
function getPointByAddressFunc(value,attname) {
if (!attname) attname = "street";
for (var x=0; x < this.addresses.length; x++) {
if (eval("this.addresses[x]."+attname) == value) {
return WAMapPoint(this.markers[x],this.addresses[x],this.icons[x]);
return WAMapPoint(this.markers[x],this.addresses[x],this.icons[x], this.points[x], this.obj);
return false;
change:
return false;
Edit/Delete Message
return false;
Edit/Delete Message
Screamin'Dean
Hi - thanks, but still no go. The .js now looks like this
this.obj = mapObj;
this.icons = [];
this.markers = [];
this.points = [];
return this;
return this;
return false;
but the map is not showing. The page link is here &#8230;
[url removed]
you have an extra "}" at the end
change:
return false;
return false;
Screamin'Dean
Thanks. .js now reads
return false;
I'm editing the code in Dreamweaver. When I remove the second } DW wants me to add another at the very end.
the full function should be:
return false;
Screamin'Dean
Thanks again, but …
I'm sorry, what is this screen shot supposed to illustrate?
I don't see anything obvious.
Screamin'Dean
Thanks, Jason. Dreamweaver still gives me the syntax error after adding your latest instruction.
The screen was meant as reference.
I dont see a syntax error in that screen shot.
regardless of Dreamweaver, does it work if you upload it?
can you send a copy of the files so I can examine the entire code.
