S is not a valid unit of measurement for weight for this shipment
Thread begun 10/06/2010 2:17 pm by movygirl244169 | Last modified 10/07/2010 7:24 am by Jason Byrnes | 1612 views | 2 replies |
movygirl244169
I'm having problems with eCart 5 and the check out. I can't get anything to work right now The error I get is "S is not a valid unit of measurement for weight for this shipment" not sure what this means but I need some help.
Miguel
What bindings do you have on the weight also are you allowing text on the wieght field?
In the shipping server behavior, make sure you have set the Weight Units to "LBS".
also make sure the Package Weight is bound to the eCart Weight column. Click the lightning bolt and select the weight column form the cart binding group.
