auto incremental numbers
Thread begun 10/06/2010 7:50 am by i.edwards384429 | Last modified 10/06/2010 10:23 am by i.edwards384429 | 2313 views | 5 replies |
i.edwards384429
Hi
I've created a database following the tutorial setting the first field a ID and makeing that auto incremental and the primary key.
I now want another field to be called product_ref to be auto incremetal and start at 5000
so I set the field name
set it to integar set it to auto increment
set the default to 5000
However when I select save I get the error
"incorrect definition there can only be one auto colum and it must be defined as a key"
where have I gone wrong
thanks
Ian
This is a limitation to MySQL
Only one column in the database can be set to Auto Increment. MySQL will not allow you to have 2 Auto Increment columns.
Willi Schneider
Originally Said By: i.edwards384429
Hi
The answer is in the error message "there can only be one auto column"
Although I think, I know what you are trying to achieve, there is no workaround for DataAssist at the moment, at least I'm not aware of any. I hope DA3 will cover such a feature.
Interakt had this in their "MX Kollection" "Nextensio" lists and forms. The solution was to run a "transaction" right before creating a new database entry, which added an "auto-increment" value to a second column.
Take a look here for a detailed explanation:
041136_setordercolumn.htm
i.edwards384429
update
thanks for the assist
Ian
Dave BuchholzBeta Tester
Ian,
you can set the initial value to increment from when setting up your table like so:
DROP TABLE IF EXISTS `tablename`;
CREATE TABLE IF NOT EXISTS `tablename` (
fields go here
) ENGINE=MyISAM DEFAULT CHARSET=utf8 AUTO_INCREMENT=5000 ;
i.edwards384429
update
Thanks Dave
I'll have a look tomorrow
Ian
