Login Not Working in IE
Thread begun 10/06/2010 7:31 am by president310264 | Last modified 10/08/2010 12:27 pm by Jason Byrnes | 5186 views | 6 replies |
president310264
I am running into some odd behavior with SecurityAssist. For some reason, my login works perfectly in all browsers except IE. When I am in IE and attempt to login, it simply refreshes the page. I am stumped as to what would cause this.
Thoughts?
~Clay
make sure the login page form fields all have a value attribute
if you continue to have problems, please send a copy of the login page so i can investigate the code.
president310264
They have value attributes. login page code is attached...
president310264
Discover anything yet?
president310264
Bump...anything yet?
president310264
Fixed!
Ok...I found the issue. It was something with the way IE handles the input form tag with the type of image. It was not processing that correctly. What I had to do to fix was change it to a submit type and all worked well. So if anyone has form submission issues with WA forms...one thing to check would be the submission input button type.
ahhh, yes, image input would make a bit of sense, in IE an image input will not pass a value, only the x and y coordinates.
another fix would have been to modify the login trigger code:
<cfif (isDefined("Form.LogIn"))>
<cfif (isDefined("Form.LogIn.x"))>
