Javascript error message stops the plug from working
Thread begun 10/05/2010 7:57 pm by Guth-Rosenstock Art | Last modified 11/16/2010 11:20 am by Jason Byrnes | 5094 views | 7 replies |
Guth-Rosenstock Art
I am using your plug on the Dreamweaver CS5 trial. I recieve this error message: "While executing onClick in wajz_valididator.htm, a JavaScript error occurred."
I cannot even get the plug to work. Is it because it is Dreamweaver CS5?
Help!!!!
Sincerely,
Joseph
Go into your site definition, in the servers section, make sure a testing server is defined.
also delete the Dreamweaver cache file from the users configuration folder:
paulshoe379536
same problem
I am having the same problem. However, I am using DW4 and it's working on other sites I have defined. I have deleted and re-created the site in DW4 and deleted the cache file. The testing server seems to be working fine, what else can I look for?
can you send a screen shot showing the site definitions settings especially the testing server settings.
paulshoe379536
site definition
image attached showing setup
I see the testing server is using a path on drive G. Is this a mapped network or local drive?
It may be an issue with using a mapped network drive. try changing that to use a local drive.
paulshoe379536
it's a local drive.. a partition on drive 2... all other test sites are set up on the same drive...
