At the end of the order complete/success page i get "headers cannot be sent"
Thread begun 10/05/2010 11:54 am by sam308940 | Last modified 10/06/2010 6:57 am by Jason Byrnes | 2712 views | 5 replies |
sam308940
Hi
everthing si workingg, but at the bottom fo the success/complete page i get the error that the headers cannot be sent.
THIS IS THE BOTTOM CODE ON THE SUCCESS PAGE
// Initialize the session.
session_start();
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (isset($_COOKIE[session_name()])) {
setcookie(session_name(), '', time()-42000, '/');
// Finally, destroy the session.
session_destroy();
AND JUST IN CASE - THIS IS THE TOP INFO
//WA eCart Include
require_once("WA_eCart/boogie_PHP.php");
?><?php
$boogie->GetContent();
if ($boogie->IsEmpty()) {
$boogie->redirStr = "cart_view.php";
$boogie->cartAction = "RedirectIfEmpty";
// WA eCart Redirect
if ($boogie->redirStr != "") {
header("Location: ".$boogie->redirStr);
Im hoping somene knows what is causing this.
in the error message it will say:
output started by /path/to/page/casing/error.php:4
this is the key to tell you what to look for.
the number after the ":" is the line number. Look in the page that the error is stating is causing the output around the line number being reported. what is the code 3 lines before to 3 lines after the reported line?
sam308940
ERROR MESSAGE
Warning: Cannot modify header information - headers already sent by (output started at /home/content/22/6698322/html/cart_complete.php:22) in /home/content/22/6698322/html/cart_complete.php on line 278
LINE 19-25 (line 22 is the metata keywords)
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/main.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<meta name="keywords" content="bear blanket, teddy bear blanket, customizable bear blanket, personalized bear blanket, custom blanket, personalized blanket, toddler blanket, kid blanket, kids blanket, personalizable blanket, customizable blanket, whimsical bear blanket" />
<meta name="description" content="Customize and personalize this handmade teddy bear blanket for babies, toddlers and kids." />
<!-- InstanceBeginEditable name="doctitle" -->
<title>Boogie Baby :: Customized and personalized handmade blankets for babies, toddlers and kids.</title>
LINE 278 is
change line 278 to:
@setcookie(session_name(), '', time()-42000, '/');
sam308940
You guys are the best! that worked!
thank you thank you thank you !!!!!
excellent, glad to hear it is working.
