Details page problem displaying extra data
Thread begun 10/05/2010 11:41 am by Brad Lawryk | Last modified 10/12/2010 6:57 pm by agmichaca | 6050 views | 22 replies |
Brad Lawryk
I have a set of Data assist pages built and they work great.
However I need to add extra data from different tables to the detail page. For example my details page shows my client profile no problem that is from the client table in the database.
I have an additional table for client notes where the administrator can enter extra notes on the particular client and I need to be able to display all the notes on that client in the profile page.
When I add the recordset to the detail page the page crashes. Now this should be a very simple thing to do as I have done it a zillion times on a non-webassist detail page.
Is there something special that is required to do this?
Brad
neilo
I had a recurring problem in CS3 & CS4, when adding a second recordset (or even editing the first and only one) whereby a duplicate block of code got added to the page. Every time.
Check your page code to make sure you only have one instance of:
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
If there is more than one such block, then delete the extra lines.
CS5 seems to have resolved this issue.
Brad Lawryk
"CS5 seems to have resolved this issue."
I am using CS5 ... but I'll give that a try
Brad Lawryk
No, I still get an error and error in the code.
On the page it says:
Parse error: parse error in C:\wamp\www\dashboard\_staff\employers\clients_Detail.php on line 63
the code error is in these lines:
$Paramclient_id_WADAclients = "-1";
if (isset()) {
$Paramclient_id_WADAclients = (get_magic_quotes_gpc()) ? : addslashes();
$Paramclient_id2_WADAclients = "-1";
if (isset()) {
$Paramclient_id2_WADAclients = (get_magic_quotes_gpc()) ? : addslashes();
$ParamSessionclient_id_WADAclients = "-1";
if (isset()) {
$ParamSessionclient_id_WADAclients = (get_magic_quotes_gpc()) ? : addslashes();
neilo
I don't know what's going wrong here.
The session variable values appear to be missing from that code. Based on what you have posted, I would expect your code to look more like:
if (isset($_GET['client_id'])) {
if (isset($_GET['client_id']))) {
if (isset($_SESSION['WADA_Insert_clientst']))) {
I am not reliable as far as php goes, so Jason or Ray would need to confirm.
Brad Lawryk
And it really makes no difference what recordset I set up. I tried with just a plain one field test table with no filtering and no sorting .... same thing.
Dani Chankhour
Do you get the same result if you removed DataAssist or do you always get that issue.
Brad Lawryk
Originally Said By: Dani Chankhour
Only happens on the Data Assist Detail page. Even if I just create a recordset that has nothing to do with the page (no filtering or sort order). And just to see if it was something on the page I went to a different site that I have Data Assist on and the same thing happens on the Data Assist Detail page on a completely different site.
Brad
Brad Lawryk
I have included the before and after code as well as a screenshot of the lines with errors.
Screenshot: codeerror.jpg
------------- Code before adding a record set: -----------
$Paramclient_id_WADAclients = (get_magic_quotes_gpc()) ? $_GET['client_id'] : addslashes($_GET['client_id']);
if (isset($_SESSION['WADA_Insert_clients'])) {
$ParamSessionclient_id_WADAclients = (get_magic_quotes_gpc()) ? $_SESSION['WADA_Insert_clients'] : addslashes($_SESSION['WADA_Insert_clients']);
$Paramclient_id2_WADAclients = (get_magic_quotes_gpc()) ? $_GET['client_id'] : addslashes($_GET['client_id']);
mysql_select_db($database_connKoparDashboard, $connKoparDashboard);
$query_WADAclients = sprintf("SELECT client_id, client_random, client_last, client_first, client_phone, client_message, client_cell, client_email, client_street, client_mailing, client_city, client_prov, client_postalcode, client_birth, client_gender, client_sin, client_maritial, client_visminor, client_aborig, client_disability, client_office, client_date, client_password, client_stafffirst, client_stafflast FROM clients WHERE client_id = %s OR ( -1= %s AND client_id= %s)", GetSQLValueString($Paramclient_id_WADAclients, "int"),GetSQLValueString($Paramclient_id2_WADAclients, "int"),GetSQLValueString($ParamSessionclient_id_WADAclients, "int"));
$WADAclients = mysql_query($query_WADAclients, $connKoparDashboard) or die(mysql_error());
$row_WADAclients = mysql_fetch_assoc($WADAclients);
$totalRows_WADAclients = mysql_num_rows($WADAclients);
if("" == ""){
$WA_mainMenu_1 = new WA_Include("../../_subs/mainMenu.php");
require($WA_mainMenu_1->BaseName);
$WA_mainMenu_1->Initialize(true);
if("" == ""){
$WA_footer_1 = new WA_Include("../../_subs/footer.php");
require($WA_footer_1->BaseName);
$WA_footer_1->Initialize(true);
------------------ Code after adding a record set: -----------------
$Paramclient_WADAclients = "-1";
$Paramclient_WADAclients = (get_magic_quotes_gpc()) ? $_GET['client_id'] : addslashes($_GET['client_id']);
$ParamSessionclient_WADAclients = "-1";
$ParamSessionclient_WADAclients = (get_magic_quotes_gpc()) ? $_SESSION['WADA_Insert_clients'] : addslashes($_SESSION['WADA_Insert_clients']);
if (isset()) {
if (isset()) {
if (isset()) {
$colname_rsClientComments = "-1";
$colname_rsClientComments = (get_magic_quotes_gpc()) ? $_GET['client_id'] : addslashes($_GET['client_id']);
$query_rsClientComments = sprintf("SELECT * FROM clientscomments WHERE clientcom_id = %s ORDER BY clientcom_date DESC", GetSQLValueString($colname_rsClientComments, "int"));
$rsClientComments = mysql_query($query_rsClientComments, $connKoparDashboard) or die(mysql_error());
$row_rsClientComments = mysql_fetch_assoc($rsClientComments);
$totalRows_rsClientComments = mysql_num_rows($rsClientComments);
if("" == ""){
if("" == ""){
Willi Schneider
Hi Brad
I've experienced these issues when using "_" underscores in my column names like "client_id".
Could you try to duplicate your table, just for testing, but avoid underscores for the table and column names? --> Then try your WADA pages again.
I know, you were also on the "Interakt train" a long time ago...
Interakt always used column names like "id_usr" and so on.
I think, DataAssist just doesn't like that naming convention.
HTH
Willi
