What files should I delete if I need to rerun eCart5 Checkout wizard?
HI,
Thank you,
Dave
HI,
Thank you,
Dave
you should delete all of the files that the checkout wizard created, these may include:
checkout.php
confirm.php
pp_confirm.php
checkout_success.php
pp_checkout_success.php
shipping_failure.php
checkout_failure.php
pp_checkout_failure.php
Thanks, Jason.
How about the files in the following folder: webassist, WA_eCart? There are a lot files associated with this. It's hard to figure out which ones should be deleted?
Dave
none of those files will need to be deleted.
Thanks, Jason.
Where are the following files:
pp_confirm.php
I did not find them.
Dave
if you can t find they may not have been created.
Not all payment gateways generate the same files, this is way my original reply stated "these may include:"
the files begining "pp_" will only be created is your payment gateway selection included paypal express checkout.
the shipping_failure page would only have been created if you selected to use one of the shipping rate lookup providers.
Thank you.
I have rerun the checkout wizard. Everything seemed OK except the shipping cost.
I used the flat shipping charge of $23.95, but the shipping cost came out as $47.90. I don't know why it doubled.
Dave
I found there are two lines of code in the file XCart_PHP.php, which are exactly same.
$this->Shipping[] = new WA_eCart_Rule(urldecode("Shipping%20&%20Handling"), true, "WAEC_XCart_ShippingHandling");
Should I delet one of them? Will this solve the problem?
Thanks,
Dave
It worked after I delete one of those lines.
Dave
dont delete the code manually, no.
edit the eCart object, i think you will see on the shipping tab that are two identical shipping rules. delete one of them there.
