Syntax Error
Thread begun 10/02/2010 2:11 pm by gpaul | Last modified 10/04/2010 8:06 am by Jason Byrnes | 1410 views | 2 replies |
gpaul
Syntax Error
I have just created a registration page, and I am getting
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ' NULL, NULL)' at line 1
This is the code (I have not modified it)
<?php require_once('Connections/local.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
// *** Redirect if username exists
$MM_flag="MM_insert";
if (isset($_POST[$MM_flag])) {
$MM_dupKeyRedirect="";
$loginUsername = $_POST['id'];
$LoginRS__query = "SELECT id FROM family WHERE id='" . $loginUsername . "'";
mysql_select_db($database_local, $local);
$LoginRS=mysql_query($LoginRS__query, $local) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
//if there is a row in the database, the username was found - can not add the requested username
if($loginFoundUser){
$MM_qsChar = "?";
//append the username to the redirect page
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername;
header ("Location: $MM_dupKeyRedirect");
exit;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "WAATKRegistrationForm")) {
$insertSQL = sprintf("INSERT INTO family (firstname, lastname, email, password, relationship, story, image, ip, submitted) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s)",
GetSQLValueString($_POST['firstname'], "text"), GetSQLValueString($_POST['lastname'], "text"), GetSQLValueString($_POST['email'], "text"), GetSQLValueString($_POST['password'], "text"), GetSQLValueString($_POST['relationship'], "text"), GetSQLValueString($_POST['story'], "text"), GetSQLValueString($_POST['image'], ""), GetSQLValueString($_POST['ip'], "text"), GetSQLValueString($_POST['submitted'], "date"));
$Result1 = mysql_query($insertSQL, $local) or die(mysql_error());
$insertGoTo = "family_LogIn.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
Thanks again for the help.
Gary
Miguel
seems it says you have soemthing wrong on your conection page to the database line 1 on that code is
<?php require_once('Connections/local.php'); ?> try checking it out that you have the password setted
can you change this line:
$Result1 = mysql_query($insertSQL, $local) or die($insertSQL);
for troubleshooting, this will tell us the sql causing the error.
