Color Choice options once again
Thread begun 6/11/2009 7:44 pm by JBWebWorks | Last modified 6/11/2009 8:32 pm by JBWebWorks | 2380 views | 2 replies |
JBWebWorks
Ray,
i am working on a new cart for a new client using the color choice nested recordset that you helped me with in a previous thread.
My question is a customer may want to order the same item in 2 or 3 different colors.
I have one item set up as a test, and adding the item and initial color choice to the cart works fine. But when i click continue shopping and add the same item with a different color choice, the cart increases the quantity, but the new color choice is not shown?
Not sure how to get this to work?
products.php
thanks for your help,
jim balthrop
Travis250923
I believe it is because in the eCart object the ID is the only column you have set as unique as that is the default. You need to make the column you setup for the options to also be a unique column so that it sees it as a different product.
JBWebWorks
Thanks for your help.
that was it; i had forgotten to make that column unique.
