Cannot send session cache limiter - headers already sent
Thread begun 9/30/2010 3:00 pm by judy392497 | Last modified 10/28/2010 9:09 am by Jason Byrnes | 4129 views | 13 replies |
judy392497
Getting this message:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/t/e/b/tebodeluxe/html/principe/confirm.php:2) in /home/content/t/e/b/tebodeluxe/html/principe/WA_eCart/WA_eCart_Definition_PHP.php on line 479
Here are lines 478 through 496:
function Session_GetContent() {
$retArray = array();
if (isset($_SESSION[$this->CartName."_Items"]) && $_SESSION[$this->CartName."_Items"] != "") {
$theCartString = $_SESSION[$this->CartName."_Items"];
$theItemArray = explode("§",$theCartString);
for ($x=0; $x<sizeof($theItemArray); $x++) {
$theValueArray = explode("|WAECART|",$theItemArray[$x]);
$toExec = "new ".$this->CartName. "_ItemDefinition(";
for ($y=0; $y<sizeof($theValueArray); $y++) {
if ($y != 0) $toExec.=", ";
$toExec .= '"'.str_replace("\'","'",addslashes($theValueArray[$y])).'"';
eval("\$nextItem =".$toExec.");");
$retArray[sizeof($retArray)] = $nextItem;
return $retArray;
the error is reporting that there is output to the confirm page around line 2:
usually it means there is a blank line or space outside of the php tags "<?php" or "?>"
look at line 1 and 2 and make sure there are no blank lines or spaces outside of the php tags.
judy392497
Solved
Perfect, thanks!
you're welcome.
paul377172
Hi I'm having a problem trying to clearing the cart but keeping the user logged in. I get this error message
Warning: session_start() [function.session-start.php]: Cannot send session cache limiter - headers already sent (output started at E:\domains\zanylane.biz\wwwroot\checkout_success.php:35) in E:\domains\zanylane.biz\wwwroot\checkout_success.php on line 69 Warning: session_regenerate_id() [function.session-regenerate-id.php]: Cannot regenerate session id - headers already sent in E:\domains\zanylane.biz\wwwroot\checkout_success.php on line 70
please compress the checkoutsuccess.php file into a zip archive.
the rtf file you have sent has converted all of the code to be double spaced. I will need to have a copy of the original php file, not the copied and pasted code.
paul377172
Ok sorry about that.
change:
session_start();
@session_start();
and change:
session_regenerate_id();
@session_regenerate_id();
paul377172
Thanks that has fixed the error messages but its still logging me out
if you are being logged out, the security assist is using a different session that "UserID" send a copy of your login page so i can see what sessions are being created on login.
