Upload Testing Working Local on Mamp but not Mamp Pro?
Thread begun 9/30/2010 1:39 pm by swbgraphix | Last modified 9/30/2010 5:20 pm by Jason Byrnes | 11028 views | 9 replies |
swbgraphix
Is there any reason you can think of that when testing our sites upload feature on the machine with MAMP it works fine, but when testing on the machine with MAMP PRO it is not working???
When our current page would not upload when testing locally on my machine with MAMP PRO, I tried rebuilding a simple upload php page to test over and over again, it would attach the file but never upload, and never show the progress bar.
Any ideas?
Do you need to see some code?
Thanks guys!
using a simple page that only includes the file upload function and nothing else, add this code to turn error reporting on:
error_reporting
(E_ALL);
also go to the bindings panel and expand the Uploaded Files Global Status group and add the debug info binding to the page, what happens testing this page?
swbgraphix
Here is the script generated:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /Volumes/SWB Graphix/04 SWBG Websites/GLtest/uploadtest.php:22) in /Volumes/SWB Graphix/04 SWBG Websites/GLtest/webassist/file_manipulation/helperphp.php on line 70
Status object: WA_UploadResult1
statusCode : 0
errorMessage : No file uploaded
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
swbgraphix
Jason I got rid of the top warning session message by deleting a blank line on 21. But the file still doesn't upload.
statusCode : 0
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
statusCode : 0
swbgraphix
My code for simple page:
error_reporting(E_ALL);
<?php require_once("webassist/file_manipulation/helperphp.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "uploadedfiles/",
'FileName' => "[FileName]",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "upload", "2", "[NewFileName]_[Increment]", "false", $WA_UploadResult1_Params);
<head>
<script src="webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body>
<div id="testform1_ProgressWrapper">
<form action="uploadtest.php" method="post" name="testform" id="testform1">
<input name="upload" type="file" />
<input name="submit" type="submit" value="submit" />
</form>
</div>
<div id="testform1_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('testform1', 'testform1_ProgressMessageWrapper', WADFP_Theme_Options['Bar:Slate']);
</script>
<div id="testform1_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="webassist/progress_bar/images/slate-bar.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
</div>
</body>
<?php echo WA_DFP_AllUploadsDebug(); ?>
</html>
for a file to upload, the forms encoding type must be set to multipart/form-data.
change the form tag:
to;
<form action="uploadtest.php" method="post" name="testform" id="testform1" enctype="multipart/form-data">
swbgraphix
I had tried that before and it didn't work. Now that error reporting is on here is what it says with that multipart/form-data added:
Warning: move_uploaded_file(/Volumes/SWB Graphix/04 SWBG Websites/GLtest/uploadedfiles/c0a53ce02993ecf3f48b6822794ecc0a_tmp.pdf) [function.move-uploaded-file]: failed to open stream: Permission denied in /Volumes/SWB Graphix/04 SWBG Websites/GLtest/webassist/file_manipulation/helperphp.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/Applications/MAMP/tmp/php/phpxavOGB' to '/Volumes/SWB Graphix/04 SWBG Websites/GLtest/uploadedfiles/c0a53ce02993ecf3f48b6822794ecc0a_tmp.pdf' in /Volumes/SWB Graphix/04 SWBG Websites/GLtest/webassist/file_manipulation/helperphp.php on line 96
Warning: copy(/Volumes/SWB Graphix/04 SWBG Websites/GLtest/uploadedfiles/c0a53ce02993ecf3f48b6822794ecc0a_tmp.pdf) [function.copy]: failed to open stream: No such file or directory in /Volumes/SWB Graphix/04 SWBG Websites/GLtest/webassist/file_manipulation/helperphp.php on line 98
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
that error means that you do not have the correct permissions on the upload directory.
make sure that the upload directory has sufficient privileges for the file to be created.
swbgraphix
Well Jason, my whole being is to be here to entertain you or as you may think "waste your time". Permissions of the file folder was the issue. Thanks for your time and patience and in the immortal words of Homer Simpsom . . . " d'oh "
no worries, it always helps to turn error reporting on when there is an issue, the errors tell the story.
