Map not displaying locally
Thread begun 9/30/2010 10:37 am by stuff55155392 | Last modified 10/01/2010 8:40 am by Jason Byrnes | 2528 views | 5 replies |
stuff55155392
I am trying to test map locally using the default API. Is this not possible to do?
yes, it is possible to use Pro Maps for Google locally.
there could be any number of different things going wrong though.
First, is it a static html page? or a dynamic page?
What is the Full URL in your browser"
what do you see if you view source of the page?
stuff55155392
static
file:///D:/Consulting%20Webs/New%20Designs/003/root/map.html
solid colored background without map itself
Directional arrows
Powered by Google
Map, Satellite, Hybrid
Terms of Use
please send a copy of the map.html file and a copy of the google_javascript folder in a zip archive.
stuff55155392
files attached
the issue is that you are testing from the file system, you need to have a local web server installed to test pro maps functionality on your local computer.
see the learning resources page for details on installing a local web server using xampp for windows:
resources.php
