Hi Kason
Thanks for the quick response. Unfortunately, I've lost my WinZip!!
However, I have created almost identical 2 pages - one without the menu, which passes the W3C test and one with, which fails.
W3Cpass.php
W3Cfail.php
Below is the code in the menu.php page
many thanks
Chris
$WA_localRoot = "/";
$WA_remoteRoot = "/";
$WA_curURL = strtolower((isset($_SERVER["PHP_SELF"]))?$_SERVER["PHP_SELF"]:"");
$assumedRoot = $WA_remoteRoot;
if (strpos($WA_curURL,strtolower($WA_localRoot)) == 0 && (strlen($WA_localRoot) >= strlen($WA_remoteRoot) || strpos($WA_curURL,strtolower($WA_localRoot)) === 0)) {
$assumedRoot = $WA_localRoot;
$WA_thisFile = $_SERVER['PHP_SELF'];
if (strpos(strtolower($WA_thisFile), strtolower($assumedRoot)) === 0) {
$WA_thisFile = substr($WA_thisFile, strlen($assumedRoot));
else {
$WA_thisFile = substr($WA_thisFile, 1);
$WA_ddsArray = explode("/", $WA_thisFile);
$WA_dotDotSlash = "";
for ($n=0; $n<sizeof($WA_ddsArray)-1; $n++) {
$WA_dotDotSlash .= "../";
// MenuWriter connection includes
require_once($WA_dotDotSlash . "Connections/connConwy.php");
// end connection includes
// MenuWriter ignore connection includes
if (1 == 0) {
<?php require_once('../../Connections/connConwy.php'); ?>
<?php } // End MenuWriter ignore connection includes ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
<ul class="level-0" id="cssmw">
<li class="parent"><a href="<?php echo($assumedRoot); ?>index.php">Home</a>
<ul class="level-1">
</ul>
</li>
<li class="parent"><a href="#">Towns & Villages</a>
mysql_select_db($database_connConwy, $connConwy);
$query_menuwriter_townsvillages = "SELECT TownID, Town, under_TownID FROM towns_villages WHERE under_TownID IS NULL AND TownActive = 'Y' ORDER BY Town ASC";
$menuwriter_townsvillages = mysql_query($query_menuwriter_townsvillages, $connConwy) or die(mysql_error());
$row_menuwriter_townsvillages = mysql_fetch_assoc($menuwriter_townsvillages);
$totalRows_menuwriter_townsvillages = mysql_num_rows($menuwriter_townsvillages);
<?php if ($totalRows_menuwriter_townsvillages > 0) { // Show if recordset not empty ?>
<?php do { ?>
<li class="parent"><a href="<?php echo($assumedRoot); ?>towns-in-conwy.php?TownID=<?php echo $row_menuwriter_townsvillages["TownID"]; ?>"><?php echo $row_menuwriter_townsvillages["Town"]; ?></a>
// MenuWriter Nested Filter Variable
$_POST["menuwriter_townsvillages1_TownID"] = $row_menuwriter_townsvillages["TownID"];
$MenuWriter_menuwriter_townsvillages1 = "-1";
if (isset($_POST['menuwriter_townsvillages1_TownID'])) {
$MenuWriter_menuwriter_townsvillages1 = (get_magic_quotes_gpc()) ? $_POST['menuwriter_townsvillages1_TownID'] : addslashes($_POST['menuwriter_townsvillages1_TownID']);
$query_menuwriter_townsvillages1 = sprintf("SELECT TownID, Town, under_TownID FROM towns_villages WHERE under_TownID = %s AND TownActive = 'Y' ORDER BY Town ASC", GetSQLValueString($MenuWriter_menuwriter_townsvillages1, "int"));
$menuwriter_townsvillages1 = mysql_query($query_menuwriter_townsvillages1, $connConwy) or die(mysql_error());
$row_menuwriter_townsvillages1 = mysql_fetch_assoc($menuwriter_townsvillages1);
$totalRows_menuwriter_townsvillages1 = mysql_num_rows($menuwriter_townsvillages1);
<ul class="level-2">
<?php if ($totalRows_menuwriter_townsvillages1 > 0) { // Show if recordset not empty ?>
<?php do { ?>
<li><a href="<?php echo($assumedRoot); ?>towns-in-conwy.php?TownID=<?php echo $row_menuwriter_townsvillages1["TownID"]; ?>"><?php echo $row_menuwriter_townsvillages1["Town"]; ?></a></li>
<?php } while ($row_menuwriter_townsvillages1 = mysql_fetch_assoc($menuwriter_townsvillages1)); ?>
<?php } // Show if recordset not empty ?>
</ul>
mysql_free_result($menuwriter_townsvillages1);
</li>
<?php } while ($row_menuwriter_townsvillages = mysql_fetch_assoc($menuwriter_townsvillages)); ?>
</ul>
mysql_free_result($menuwriter_townsvillages);
</li>
<li class="parent"><a href="<?php echo($assumedRoot); ?>listings_Search.php">Search & Listings</a>
$query_menuwriter_listtype = "SELECT LT_ID, ListType FROM list_type ORDER BY LT_ID ASC";
$menuwriter_listtype = mysql_query($query_menuwriter_listtype, $connConwy) or die(mysql_error());
$row_menuwriter_listtype = mysql_fetch_assoc($menuwriter_listtype);
$totalRows_menuwriter_listtype = mysql_num_rows($menuwriter_listtype);
<?php if ($totalRows_menuwriter_listtype > 0) { // Show if recordset not empty ?>
<?php do { ?>
<li><a href="<?php echo($assumedRoot); ?>listings.php?lt=<?php echo $row_menuwriter_listtype["LT_ID"]; ?>"><?php echo $row_menuwriter_listtype["ListType"]; ?></a></li>
<?php } while ($row_menuwriter_listtype = mysql_fetch_assoc($menuwriter_listtype)); ?>
</ul>
mysql_free_result($menuwriter_listtype);
mysql_free_result($menuwriter_listings);
</li>
<li class="parent"><a href="<?php echo($assumedRoot); ?>tours.php">Tours</a>
$query_menuwriter_listings = "SELECT ListID, ListName, ListType FROM listings WHERE ListType=6";
$menuwriter_listings = mysql_query($query_menuwriter_listings, $connConwy) or die(mysql_error());
$row_menuwriter_listings = mysql_fetch_assoc($menuwriter_listings);
$totalRows_menuwriter_listings = mysql_num_rows($menuwriter_listings);
<?php if ($totalRows_menuwriter_listings > 0) { // Show if recordset not empty ?>
<?php do { ?>
<li><a href="<?php echo($assumedRoot); ?>listingdetails.php?ListID=<?php echo $row_menuwriter_listings["ListID"]; ?>"><?php echo $row_menuwriter_listings["ListName"]; ?></a></li>
<?php } while ($row_menuwriter_listings = mysql_fetch_assoc($menuwriter_listings)); ?>
</ul>
</li>
<li><a href="<?php echo($assumedRoot); ?>activities.php">Things to do</a></li>
<li><a href="<?php echo($assumedRoot); ?>registration.php">Register</a></li>
<li><a href="<?php echo($assumedRoot); ?>contact.php">Contact</a></li>
<li><a href="<?php echo($assumedRoot); ?>login.php">Log In</a></li>
</ul>
<script type="text/javascript">if(window.attachEvent) { window.attachEvent("onload", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }); } else if(window.addEventListener) { window.addEventListener("load", function() { cssmw.intializeMenu('cssmw',{select_current: 0, orientation: 1}); }, true); }</script>
