Display Numbers of Items on Cart
Thread begun 9/30/2010 3:31 am by rafael.ordaz410005 | Last modified 10/12/2010 7:39 am by Jason Byrnes | 1783 views | 3 replies |
rafael.ordaz410005
I would like to display the number of items in the cart. Is there any variable available I can use for that or guidance to accomplish this
Thanks.
ECART: 4.5.2 / ASP
for ASP VBScript, use this code to show the number of items in the cart.
<%=WA_eCart_TotalColumn(yourCart, "Quantity")%>
where yourCart is the name of your eCart object.
Tip: you can get this code by adding a Quick Cart display using the eCart Display Manager
rafael.ordaz410005
Jason,
Thanks for the Tip!, since I'm using ASP / Javascript I used the following line of code:
<%=MyCart.TotalColumn("Quantity")%>
You're welcome.
