Images are being truncated
Thread begun 9/29/2010 9:12 pm by Jim376112 | Last modified 10/26/2010 10:38 am by Jim376112 | 3105 views | 6 replies |
Jim376112
Hello,
I have PowerGallery working but all of my photos are being truncated (lots of "heads getting chopped off"!). I understand that when you "Add Photos" in the Admin app that they are sized but it looks like something is going wrong.
I don't see any information about "max sizes" or any controls that might affect this. Can someone please tell me how to address this problem?
Thanks.
Justin Nemeth
It depends on what gallery you are using. Some of the galleries are designed to a fixed image size and the use cropped images to ensure they are all the same size. The galleries do that by default.
If you want to change it, open up the index.php for the gallery you are using on line 11 or so there will be a gallery URL string that is built up. Look for something like 999c in that url. You can change the size to match another image size that you have defined in the common/properties.php file.
There are quite a few other threads that have specific code on how to change the image size in a gallery.
-justin
Jim376112
Hi Justin,
Thanks for clarifying what's happening; I didn't realize some Galleries crop be design (I assumed images would always just be resized!).
I searched on "change image size" and found several interesting posts and I think I'm starting to see how this works, but I have a couple of questions:
1) It looks like the "c" and "p" indicate "cropped" and "proportional" - can I just change the "c" in the URL in index.php for slideshow_disssolve to get it to resize rather than crop? Do I need to reprocess all of the images for this to work and how would I do that?
2) Reading the posts confirms a response you gave me on a previous post and that is that images are actually resized when they are "uploaded". Plus, I guess thumbnails are also created. A) where are the resized images stored and B) where are the thumbnails placed?
Thanks.
Justin Nemeth
Yes, the c and p are for cropped and proportional. You can just change the sizes, but you'll also need to look in the common/properties.php file and make sure the size is also listed in there. There are 2 arrays with sizes for cropped and proportional, so edit those arrays as needed for your size.
Reprocessing the images can be done by selecting your gallery, then processing the watermark. Even if the watermark is blank, that will force the new sizes to be created.
Images are stored in the images/[gallery ID] folder. You'll see the originals and all the sized images in there - with the size and c or p suffix.
-justin
Jim376112
Hi Justin,
Wow - your answers just revealed something surprising! I didn't realize that there were so many images created for each original image. Here are some follow on questions:
1) Each image I uploaded has ten images associated with it; a copy of the original and nine "c & p" versions. Why does PowerGallery create so many versions when the files are "uploaded"? Isn't this a huge waste of storage space? Can I instruct PowerGallery to only generate what is needed for the particular Gallery I select?
2) If all these versions are already created, why is any processing needed if I want to change the Gallery style? Or is your instruction to "process an 'empty' watermark" only needed if I have added a new size to the code?
3) Since we have all of these versions of each file, is there any reason I can't delete (from the server) the files that I originally uploaded that were processed by PowerGallery when I selected a Gallery style?
Thanks.
Justin Nemeth
1) It creates various sizes so that all the of the gallery types can be used with no additional processing. You just switch the gallery type and its good to go since the images exist. It takes up more space yes, but generally hosts these days give large amounts or even unlimited space. You would have to customize the code yourself to create these image at a different time and not upload.
2) Processing is only needed if you add a new size to that properties.php file, if you are using a size that already exists, no need to process the images again.
3) We keep the originals so that any new sizes, watermarks, or rotations use the original source. This gives the best quality possible. I would recommend keeping the originals unless you never plan on processing the images after they are setup. Keep in mind that if those images aren't there and you try to process it won't work.
-justin
Jim376112
Hi Justin,
(Sorry for the delay in responding!) Thanks for all the good info. I've implemented the changes as you selected and all is working well.
Thanks.
