Email Form Fields From DB insert.
Thread begun 9/28/2010 6:15 pm by jeff_bannister384197 | Last modified 9/29/2010 6:25 am by Jason Byrnes | 1525 views | 1 replies |
Hi There,
I am using Universal email to try and email me the form data after it has been inserted into the DB, however I am not sure how to get Universal email to get the individual record upon the insert? The form has 15 fields that area inserted into the record and I just what those to be recorded in the DB (which they currently are) and then sent via email.
Attached is the page code.
On the display page for the email I am trying to pull the data like so {UserFirstName}
Any help is appreciated.
you don't need to use a recordset for this.
Make sure that the insert record behavior does not redirect to another page after the record is inserted, then add Universal Email to the same page.
If you select the option to Create an Page for the email, and select to use one of the templates from the dropdown list, all of the code needed to write the form data to the email will automatically created for you.
You can set the Universal Email behavior to redirect to the thank you page after the email is sent.
