Multiple edit does not work
Thread begun 9/28/2010 5:19 pm by alan_croft399018 | Last modified 10/10/2010 1:59 am by Dave Buchholz | 6344 views | 13 replies |
alan_croft399018
Hi
Have recently purchased Data Assist 2. Have created a multiple insert page and it is working ok. Tried to create a multiple update page, while the page comes up with the required fields when the submit button is pressed it does not update nor does it go to the "go to" page. Have followed your tutorial, after many attempts always the same result. Attached the code for the page can you assist please.
<?php require_once('../Connections/connvbsa.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_connvbsa, $connvbsa);
$query_Team_Score_Edit = "SELECT team_id, team_name, team_grade, Result_pos, Result_score, HB FROM Team_entries WHERE Team_entries.team_grade='APB'";
$Team_Score_Edit = mysql_query($query_Team_Score_Edit, $connvbsa) or die(mysql_error());
$row_Team_Score_Edit = mysql_fetch_assoc($Team_Score_Edit);
$totalRows_Team_Score_Edit = mysql_num_rows($Team_Score_Edit);?>
// WA DataAssist Multiple Updates
if (isset($_POST["button_<?php echo $RepeatSelectionCounter_1; ?>"])) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_team_id");
$WA_connection = $connvbsa;
$WA_table = "Team_entries";
$WA_redirectURL = "Ladders.php";
$WA_keepQueryString = false;
$WA_indexField = "team_id";
$WA_fieldNamesStr = "Result_pos|Result_score|HB";
$WA_columnTypesStr = "none,none,NULL|none,none,NULL|',none,''";
$WA_connectionDB = $database_connvbsa;
$WA_multipleUpdateCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleUpdateCounter)) {
$WA_fieldValuesStr = "".$row_Team_Score_Edit['Result_pos'] ."" . "|" . "".$row_Team_Score_Edit['Result_score'] ."" . "|" . "".$row_Team_Score_Edit['HB'] ."";
$WA_where_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleUpdateCounter);
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
$WA_multipleUpdateCounter++;
if ($WA_redirectURL != "") {
?><?php
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "1";
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<!-- DW6 -->
<head>
<title>VBSA Administrative area</title>
<script src="../Scripts/AC_RunActiveContent.js" type="text/javascript"></script>
<link href="../CSS/vbsa_DB.css" rel="stylesheet" type="text/css" />
</head>
<body>
<center>
<form id="form1" name="form1" method="post" action="">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_Team_Score_Edit){
<table border="0">
<?php do { ?>
<tr>
<td>Team</td>
<td><input type="hidden" name="WADA_RepeatID_team_id_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_team_id_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_Team_Score_Edit["team_id"]; ?>" />
<input type="text" name="Result_pos_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo htmlentities($row_Team_Score_Edit['Result_pos'], ENT_COMPAT, 'utf-8'); ?>" size="32" /></td>
<td><input type="text" name="Result_score_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo htmlentities($row_Team_Score_Edit['Result_score'], ENT_COMPAT, 'utf-8'); ?>" size="32" /></td>
<td><input type="text" name="HB_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo htmlentities($row_Team_Score_Edit['HB'], ENT_COMPAT, 'utf-8'); ?>" size="32" /></td>
</tr>
<?php } while ($row_Team_Score_Edit = mysql_fetch_assoc($Team_Score_Edit)); ?>
<tr>
<td>&nbsp;</td>
<td><input type="submit" name="button_<?php echo $RepeatSelectionCounter_1; ?>" id="button_<?php echo $RepeatSelectionCounter_1; ?>" value="Submit" /></td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<td>No records match your request.</td>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_Team_Score_Edit && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
?></form>
</center>
</body>
</html>
mysql_free_result($Team_Score_Edit);
Dave BuchholzBeta Tester
Alan,
I think you have encountered a bug as the repeat selection code is in the wrong place, your table code should look like this:
<table border="0">
<?php do { ?>
while(
$RepeatSelectionCounter_1_IterationsRemainin g--){
if(
<tr>
<td>Team</td>
</tr>
else{
if(!
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
</form>
try that and see what happens
alan_croft399018
Thanks Dave
Still the same, I shifted the code around as per yours to see what changes were required and could not get it to work. I then copied a your code completely and still no go. Here is the current code for the page. The page comes up with no errors, entries can be changed, when you click the submit button it does not redirect to the ladders page but simply reverts to the original entries? You suggest there may be a "bug" how do I fix that? Thankyou for your assistance
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
?><?php
<!-- DW6 -->
<head>
</head>
<body>
<center>
<table border="0">
<?php do { ?>
<tr>
<td>Team</td>
</tr>
else{
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
</form>
</center>
</body>
</html>
The bug I mentioned relates to where the repeating code is placed, your issue now relates to the name of the button and the trigger code:
Change this code:
to
if (isset($_POST["button)) // Trigger
and this code:
to
<td><input type="submit" name="button" id="button" value="Submit" /></td>
and you should be good to go
alan_croft399018
Thanks again Dave
We have some action, problem, it updates all fields for all teams with the inputs for team 1, have looked at the table in my c panel and all fields are the same as for team_ID 1. Is it something I have done or is it always this difficult to get a multiple update page to work? I noticed when I created the multiple insert page that some of the code went into the wrong place on the page and was able to fix that myself, maybe I just got lucky? One starts to doubt if "data assist" is a worthwhile investment. I am no expert in php, I would like to be able to write the code myself but do not have that ability. For us dreamweaver users the only option is to buy "extensions" or search the web for tutorials, I sincerely hope we can get this to work as I have built a scoring system that, while it works is cumbersome to use and will require a few of these type of pages to make it easier to use. I am using CS3 does that make a difference?
Really appreciate your assistance
The current code is:
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
if (isset($_POST["button"])) // Trigger
?><?php
<!-- DW6 -->
<head>
</head>
<body>
<center>
<table border="0">
<?php do { ?>
<tr>
<td>Team: <?php echo $row_Team_Score_Edit['team_id']; ?></td>
</tr>
else{
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
</form>
</center>
</body>
</html>
Where did this code come from ?
$RepeatSelectionCounter_1_Iterations = "".$row_Team_Score_Edit['team_id'] ."";
it should read
alan_croft399018
Hi Dave
Sorry, still no success. Have edited the code in the previous reply to reflect the current code. Thanks again for your assistance
Alan,
post your pages and a database dump and I'll investigate further
alan_croft399018
Hi Dave
Not sure what you mean by "database dump" but here is current code
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
?><?php
<!-- DW6 -->
<head>
</head>
<body>
<center>
<table border="0">
<?php do { ?>
<tr>
</tr>
else{
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
</table>
</form>
</center>
</body>
</html>
Alan,
can you zip up all the pages that relate to this page, details page, search etc. plus the sql file for your database so that I have your data to work with.
