Theme modify doesn't work in CS 3 or 5
Thread begun 9/28/2010 8:25 am by peacehawk | Last modified 9/28/2010 11:56 am by Jason Byrnes | 1041 views | 1 replies |
peacehawk
Hi, I'm using both CS 3 & 5 and after making a page I wish to modify the theme only to have the modify screen flash before me and disappear. I've put up with this now for quite a while and well, I like to have it work properly.
I'm on a macpro using snow leopard, latest update, and Css Menu Writer v 2.03. I can open from the drop down menus but, hey I like to know that the work I modifying will go to the desired menus.
Also, when using the Edit Content feature it always give me a message; Error generating menu(wa.generate.menu): TypeError: this orientations[orientation] has no properties. This function too I like to work properly. This function has never work either in my macpro or my G5; ever.
Looking forward to the solution. PS, you guys & gals are the best.
Phone: 646-360-5581 (just in case)
Jim Graniela
2.03 is not compatible with CS5, you should update to version 2.05.
you may also need to delete the bundle files in the JSEtesnions folder of the Users Configuration.
To locate the users configuration folder, see this pdf:
Inside the configuration folder, go to the JSExtensions folder and delete any file that ends in .bundle.
