Adding FirstData with eCart
Thread begun 9/27/2010 9:25 pm by johnb | Last modified 9/28/2010 11:38 am by Jason Byrnes | 1416 views | 2 replies |
johnb
- Using PS3
I have gone through the steps in the /ps_change_pmtgateway_ecart.pdf to the "T". Actually more than a few times and I keep getting the same PHP error message. Once I run through the checkout and proceed to the confirm page I keep getting this error:
Parse error: syntax error, unexpected $end in /home/hosting/public_html/confirm.php on line 1685
I am not doing anything outside of the instructions and I only get this error after following them. If I run the checkout process using the confirm file before I edit it with eCart it doesn't spit out the error.
Any suggestions? I need to take this live for my client ASAP.
johnb
Figured it out
Okay Webassist, you need to fix the PDF as it tells people to strip code from the page which leaves opened braces.
This is the code we are asked to remove:
if($WAGLOBAL_Gateway == 2) { //Check your setting in the WA_Globals to ensure you are using the correct gateway
?><?php
// process payment with Authorize.net
} //end gateway check for Authorize.net
if($WAGLOBAL_Gateway == 1 ) { //Check your setting in the WA_Globals to ensure you are using the correct gateway
} //end paypal gateway
} //end test mode... if test mode, redirect to success page
else if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) {
$WA_Store_Cart->redirStr = "checkout_success.php";
And n my case it left this open:
// if in test mode, skip all checkout code
if ($WAGLOBAL_Test_Mode != true) {
// if Using Authorize.net
As in there was no longer a "}" since I stripped it with the first portion. (it is just before the "?>" at the end of the code.
Hopefully someone else with a similar problem will find this use full.
Thanks for bringing this to our attention, I have forwarded this to the documentation team for review.
