Multiple Delete
Thread begun 9/27/2010 2:55 pm by Cologne | Last modified 9/27/2010 3:18 pm by Jason Byrnes | 1593 views | 1 replies |
Cologne
Multiple Delete
can someone take a look and tell me whats wrong here? It will not delete :-(
<?php session_start(); ?>
<?php require_once('../data/IchBinMusiker.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once( "../WA_SecurityAssist/Helper_PHP.php" ); ?>
if (!WA_Auth_RulePasses("admin")){
WA_Auth_RestrictAccess("../noaccess.php");
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_IchBinMusiker, $IchBinMusiker);
$query_unconfirmeduser = "SELECT memberid FROM member WHERE confirmed = 0";
$unconfirmeduser = mysql_query($query_unconfirmeduser, $IchBinMusiker) or die(mysql_error());
$row_unconfirmeduser = mysql_fetch_assoc($unconfirmeduser);
$totalRows_unconfirmeduser = mysql_num_rows($unconfirmeduser);
$query_confirmeduser = "SELECT memberid FROM member WHERE confirmed = 1";
$confirmeduser = mysql_query($query_confirmeduser, $IchBinMusiker) or die(mysql_error());
$row_confirmeduser = mysql_fetch_assoc($confirmeduser);
$totalRows_confirmeduser = mysql_num_rows($confirmeduser);
$query_profilesonline = "SELECT profileid FROM profile WHERE publicview = 1";
$profilesonline = mysql_query($query_profilesonline, $IchBinMusiker) or die(mysql_error());
$row_profilesonline = mysql_fetch_assoc($profilesonline);
$totalRows_profilesonline = mysql_num_rows($profilesonline);
$query_expireduser = "SELECT member.memberid, member.firstname, member.lastname, member.email, member.`timestamp` FROM member WHERE member.confirmed = 0 AND DATE_ADD(member.`timestamp`, INTERVAL 2 HOUR) <= (NOW())";
$expireduser = mysql_query($query_expireduser, $IchBinMusiker) or die(mysql_error());
$row_expireduser = mysql_fetch_assoc($expireduser);
$totalRows_expireduser = mysql_num_rows($expireduser);
// WA DataAssist Multiple Deletes
if (isset($_POST["button"])) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_memberid");
$WA_loopedField = array("delete");
$WA_connection = $IchBinMusiker;
$WA_table = "member";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "memberid";
$WA_columnTypesStr = "none,none,NULL";
$WA_fieldNames = explode("|", $WA_indexField);
$WA_comparisions = array("=");
$WA_connectionDB = $database_IchBinMusiker;
$WA_multipleDeleteCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleDeleteCounter)) {
if (WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleDeleteCounter) == WA_AB_getLoopedFieldValue($WA_loopedField[0], $WA_multipleDeleteCounter)) {
$WA_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleDeleteCounter);
$WA_fieldValues = array($WA_fieldValuesStr);
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
$WA_multipleDeleteCounter++;
if ($WA_redirectURL != "") {
// RepeatSelectionCounter_1 Initialization
$RepeatSelectionCounter_1 = 0;
$RepeatSelectionCounterBasedLooping_1 = false;
$RepeatSelectionCounter_1_Iterations = "1";
<head>
<title>Adminbereich</title>
</head>
<body>
<p><a href="../logout.php">Logout!</a></p>
<p>Bestätigte Anmeldungen: <?php echo $totalRows_confirmeduser ?></p>
<p>Unbestätigte Anmeldungen: <?php echo $totalRows_unconfirmeduser ?> </p>
<p>Profile online: <?php echo $totalRows_profilesonline ?></p>
<form id="formExpiredMember" name="formExpiredMember" method="post" action="">
// RepeatSelectionCounter_1 Begin Loop
$RepeatSelectionCounter_1_IterationsRemaining = $RepeatSelectionCounter_1_Iterations;
while($RepeatSelectionCounter_1_IterationsRemaining--){
if($RepeatSelectionCounterBasedLooping_1 || $row_expireduser){
<table width="500" border="0" cellspacing="0" cellpadding="0">
<tr>
<td colspan="2">Abgelaufenen Datensätz:</td>
</tr>
<?php do { ?>
<tr>
<td width="373"><?php echo $row_expireduser['memberid']; ?><br />
<?php echo $row_expireduser['timestamp']; ?><br />
<?php echo $row_expireduser['firstname']; ?><?php echo $row_expireduser['lastname']; ?><br />
<?php echo $row_expireduser['email']; ?><br /></td>
<td width="20"><input type="hidden" name="WADA_RepeatID_memberid_<?php echo $RepeatSelectionCounter_1; ?>" id="WADA_RepeatID_memberid_<?php echo $RepeatSelectionCounter_1; ?>" value="<?php echo $row_expireduser["memberid"]; ?>" />
<input type="checkbox" name="delete_<?php echo $RepeatSelectionCounter_1; ?>" id="delete_<?php echo $RepeatSelectionCounter_1; ?>" value='<?php echo $row_expireduser["memberid"]; ?>' /></td>
</tr>
<?php } while ($row_expireduser = mysql_fetch_assoc($expireduser)); ?>
<tr>
<td colspan="2" align="right"><input type="submit" name="button_<?php echo $RepeatSelectionCounter_1; ?>" id="button_<?php echo $RepeatSelectionCounter_1; ?>" value="Löschen" /></td>
</tr>
</table>
} // RepeatSelectionCounter_1 Begin Alternate Content
else{
<td>Keine abgelaufenen Datensätze vorhanden.</td>
<?php } // RepeatSelectionCounter_1 End Alternate Content
if(!$RepeatSelectionCounterBasedLooping_1 && $RepeatSelectionCounter_1_IterationsRemaining != 0){
if(!$row_expireduser && $RepeatSelectionCounter_1_Iterations == -1){$RepeatSelectionCounter_1_IterationsRemaining = 0;}
$RepeatSelectionCounter_1++;
} // RepeatSelectionCounter_1 End Loop
</form>
</body>
</html>
mysql_free_result($unconfirmeduser);
mysql_free_result($confirmeduser);
mysql_free_result($profilesonline);
mysql_free_result($expireduser);
your submit button is inside the repeat region.
change:
<td colspan="2" align="right"><input type="submit" name="button_<?php echo $RepeatSelectionCounter_1?>" id="button_<?php echo $RepeatSelectionCounter_1?>" value="Löschen" /></td>
<td colspan="2" align="right"><input type="submit" name="button" id="button" value="Löschen" /></td>
and move it so it is outside the repeat region.
in the future please compress the php page into a zip archive and attach the zip file to your message instead of pasting the page code.
