Close window on update
Thread begun 9/26/2010 1:38 pm by nickj | Last modified 10/07/2010 5:16 am by Dave Buchholz | 1890 views | 5 replies |
nickj
I hae a small form in a popup (behavior-open browser window). I want to just close the window when the update button is clicked!
How?
Nick
Dave BuchholzBeta Tester
You would need to do this via JavaScript, this link should help
nickj
THank you, I had that script but can I apply this to a submit button? If so how? setting the re-direct opens the next page in the pop up. Can I set "parent" as a target with a submit/update button?
you can set target as part of the form properties
nickj
Back to this problem. I have a WA update form in a iframe, the redirect is set in the wizard and does not offer a target as an option for teh redirectURL. I tried adding:
// WA Application Builder Update....
$WA_redirectURL = "http://xyz.com/123_pay.php target"parent"";
but it fails. So What I need to do is to click the update button aqnd have the redirect open in a new page.
try adding this code to the page contained in the iframe
if (top.location!= self.location) {
top.location = '<?php echo $WA_redirectURL; ?>';
</script>
